Selling my 2009 VW CC Sport 2.0t 6 speed manual
Mocha Brown Metallic
130,500 miles and climbing
· Updated chain tensioner
· APR Carbonio Stage 1 intake
· EuroJet 3" SS downpipe with high flow cat, O2 spacer - no cel
· Unitronic Stage 2 (93 octane) tune
· BFI Heavy shift knob
· R8 coil packs
· New South Boost Gauge (center pod on steering columnn)
· Airlift Slam Series air ride, V2 controller in cubby, Shorty rear struts, 5 gallon skinny tank, Vlair black 480 cc compressor, 3/8" lines. Just did bushing refresh kit on both fronts.
· Notched Frame
· Just-installed clutch with all new parts - TT-S pressure plate, Euro TDI disk, Luk DMFW, 1-piece metal TOB, rear main seal
· New OEM rotors and pads all around this January
· Trunk wiring harness just repaired
· Oil just changed with OEM filter, oil pan bolt, LiquiMoly NextGen oil
The bad:
· Intermittent airbag light - scanned - needs new PS passenger detection module (PN 3C8959339)
· Front DS seat has small, partial tear in leather on outer bolster
· Trunk has rust forming near water drain grommet (not visible when trunk is closed), on front DS fender
· After driving in hard rain, there is a squeak when turning at low speeds until whatever's squeaking dries out. May be LCA bushings.
· Some small dings/dents from daily driving it for the past 7+ years
None of these issues affect driveability.
Will be selling with stock Phoenix 17x8 wheels with Continental DWS 06. Two bought last year, two bought the year before.
$7000 OBRO.
Thanks.
· R8 coil packs
· Notched Frame
The bad:
$7000 OBRO.
Thanks.
