I decided to rebuild my trunk, and cut down the equipment.
Memphis M3 Mojo 15'' sub:
Dual 4ohm voice coils
1000W RMS
2000W+ peak
Sub weighs 68lbs
On ebay, they have opening bids between $200 and $250 for used subs.
New they are $550. I have used it for about 2 months, and it maybe has 15 hours on it.
Memphis Big Bell 1300:
* User Selectable 12dB or 18dB Per Octave Crossover Slope
* Built In Fully Variable Sub-Sonic Filter on channel 5
* 5-Channel MClass Series Amplifier
* Class-AB / Class-D Hybrid Amplifier
* Compact Aluminum Chassis with Custon Black Pearl Finish
* Gold Plated RCA Connectors
* Full MOSFET Design
* Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4)
* Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5)
* 4-Way Protection Circuitry
* Platinum Finish Wire Connections
* Accepts 4 Gauge Power and Ground Wire
* Optional Wired Remote Gain Control
* Adjustable Input Sensitivity: 200mV - 4V
* Dimensions: 25.81" L x 7.6" W x 2.4" H
* Number of Channels 5
* RMS Power (4 ohms) 75 watts x 4 chan. + 300 watts x 1 chan.
* RMS Power (2 ohms) 115 watts x 4 chan. + 600 watts x 1 chan.
* RMS Power (1 ohm) Stable + 1100 watts x 1 chan.
* Bridged RMS Power 230 watts x 2 chan.
* Peak Power Output 3120 watts approx.
* Min. Impedance Unbridged 2 ohms (Channels 1-4), 1 ohm (Channel 5)
* Min. Impedance Bridged 4 ohms
* THD @ Rated RMS Power 0.03 %
* Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz) + LP (50 - 250 Hz), Subsonic (20 - 50 Hz)
* Signal-to-Noise Ratio 95 dB
* Fuse Rating 30A x 6
These sell on ebay for $750 and new in stores for $1000.
Mine is in MINT condition and has maybe 100 hours on it.
$700 for the amp
$200 for the sub
1000W RMS
2000W+ peak
Sub weighs 68lbs
$700 for the amp
$200 for the sub
