1 - 2 of 2 Posts
I know, I'm the first to tell people that this is a technical forum and not the classifieds. I need more coverage.
This amp has maybe 20 hours on it. I had it in the car for about 2 weeks, when it developed a problem. Memphis fixed it under warranty (which it still has over a year left of) and I decided to redesign my trunk and only use one, instead of the two that I originally had installed. This has been sitting in my living room for about 9 months. Just so you aren't scared away, the second amp that I have has been flawless for almost two years.
There is currently one for sale on ebay for $700, and they retail for $1100.
The specs on this amp are:
User Selectable 12dB or 18dB Per Octave Crossover Slope
Built In Fully Variable Sub-Sonic Filter on channel 5
5-Channel MClass Series Amplifier
Class-AB / Class-D Hybrid Amplifier
Compact Aluminum Chassis with Custon Black Pearl Finish
Gold Plated RCA Connectors
Full MOSFET Design
Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4)
Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5)
4-Way Protection Circuitry
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
Optional Wired Remote Gain Control
Adjustable Input Sensitivity: 200mV - 4V
Dimensions: 25.81" L x 7.6" W x 2.4" H
Number of Channels 5
RMS Power (4 ohms) 75 watts x 4 chan. + 300 watts x 1 chan.
RMS Power (2 ohms) 115 watts x 4 chan. + 600 watts x 1 chan.
RMS Power (1 ohm) Stable + 1100 watts x 1 chan.
Bridged RMS Power 230 watts x 2 chan.
Peak Power Output 3120 watts approx.
Min. Impedance Unbridged 2 ohms (Channels 1-4), 1 ohm (Channel 5)
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power 0.03 %
Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz) + LP (50 - 250 Hz), Subsonic (20 - 50 Hz)
Signal-to-Noise Ratio 95 dB
Fuse Rating 30A x 6
1 - 2 of 2 Posts
