1 - 6 of 6 Posts
Discussion Starter #1
This is an obd2 vr6 w/ 126,000 miles. Engine is very clean but I've never heard it run...Turns over smooth w/ no noises, but not sure of condition..Bought the car as parts..Inside the car has a rats nest of wires from an aftermarket alarm system..When I got the car you could'nt even turn it over because of the starter diabler.I have since bypassed that,but you still can't hear the fuel pump running when you crank it..I'm sick of the alarm mess and trying to figure it out..The engine harness from the fuse box out is un moelested from what I've seen..I'm sure it's the alarm issue thats keeping it from running..Come get it..located approx 45 minutes north of Harrisburg Pa.. $600 obo
Discussion Starter #3
Re: FS OBD2 vr6 engine and harness..Pa pick up only (callawayrocco82)
$500 cash!! pulled side cover..needs chains 4 sure, but chains din't snap...One rail is worn pretty good....$500 cash!
Discussion Starter #4
no fuel pressure in the lines may have caused it not to run...you think?
$500 come one...chains are $144 from MJM!!!!!
Discussion Starter #6
The harness and ecu is gone....$400 for the complete motor, just needs chains..
1 - 6 of 6 Posts
