Real Rieger 3 bar, not a knock off. Painted lk4z Brombeer metallic. Trimmed to fit perfectly. one tab was slightly busted, but works and mounts fine. I can fix it if you'd like. I'll prep and prime it per request as well. Its straight as an arrow. $100 shipped firm.
Exhaust tip..made by Thermal r&d. Stainless 4".. has 3" ss pipe welded to it..can weld on or clamp on your exh., your choice.
25 bucks shipped
E-fan 12v puller. Works perfectly. Don't know who makes it but it works great and is real thin.
$25 shipped.
T-bolt clamps: 2.5" 3" and 3.5" all brand new. Some are Turbonetics, some are Jegs, Clampco etc.. all the same sht
No nuts, but you can find them at any hardware store for 50 cents.
$25 shipped.
Good working 02 sensor. 4 wire. Just chop off the connector and wire it up like a universal unit.
-6 AN fittings. All brand new. Made by Earls / Fragola. 2 straight fittings, 1 tee, 2 barb to -6's, union adapter and female to female coupling.
$25 shipped
Aluminum oil pans, no cracks or leaks etc. They are from 1.9 tdi motors I believe. I have 3 of the same pan. $50 shipped each
obd2 4 cyl throttle body. Works perfectly. 2.0 8v maybe? $50 bucks.
Modified by dasbeast3.0 at 10:30 PM 3-23-2010
25 bucks shipped
$25 shipped.
$25 shipped.
$25 shipped
