FS: right E-Code Audi TT HID headlight
564 Views 0 Replies 1 Participant Last post by  Bora20
8
I bought this headlight USED from Germany and I have taken the parts out that I needed. The only parts that I removed from the headlight were the HID projector and D2S bulb. Everything else is intact and I have no use for it.
So I am selling the headlight to all of you. It is a right TT HID headlight, minus the HID projector and D2S bulb.
It includes:
- complete housing with instact mounting clips, nothing broken on this one
- housing DOES NOT have the NA spec amber reflector
- foglight projector w/bulb
- high beam reflector with main bulb and standing light bulb
- HID ballast, igniter, high voltage D2S/D2R bulb connector
- levelling motor
- there is some minor pitting on the front lens
Though the projector is gone, your NA spec TT projector will bolt right into place. You can also use a BMW right HID projector as they are the same.
If you have any questions, please email me and I will get back to you ASAP. I am not sure what it is worth, but make me an offer. I will be away for work from Aug 6th - 17th so be patient if you want it.
[Modified by Bora20, 12:50 PM 8-4-2002]
See less See more
1 - 1 of 1 Posts
1 - 1 of 1 Posts
