Whole setup used for ~ 6 months. Just going to something different.
Rockford Fosgate P1200.2 - Retail: $900
- Class A/B
- 2 Channel
- Actual Rated Power: 722W RMS @ 2 ohms PER CHANNEL, 410W RMS @ 4 ohms PER CHANNEL.
Rockford Fosgate P450.4 - Retail: $450
- Class A/B
- 4 Channel
-Actual Rated Power: 110W RMS @ 4 ohms, 120W RMS @ 2 ohms.
Rockford Fosgate P3 12" - Retail: $300 each.
- 500W RMS, 1000W max each.
- 96 OZ dual stacked magnets each.
Enclosure - At least $300 if you had a shop build it.
- Professionally Built
- Dual Chamber
- Sealed
- ~1.01 cu. ft. per chamber, ideal specifications for a sealed enclosure for the woofers.
The P1200.2 has one slight issue. The left channel's positive terminal (which is a clamp; tighten the screw the bottom clamp comes up) doesn't not clamp up. It seems like it fell off the track. I've been using this amplifier like this for 6 months (since I put it in) with no issues (the wire is shoved in there as I'm using 12AWG Rockford wiring).
I have 2 replacement pieces (they sent me two) that can be soldered on or you can send it to Rockford for repair (quoted $150-175 from Rockford themselves).
The whole set up would cost around $2200 retail. I was looking for $1000, but with the 2 channel needing to be fixed I'm looking for $850 for the whole setup (both amps, both subs, and the enclosure).
If you want the subs, box, and sub amp I am looking for $750.
Here is a picture of the box and the amps (I took off the false floor cover and the connection covers so you can see the amps).
Uploaded with ImageShack.us
- Class A/B
- 2 Channel
- Class A/B
- 4 Channel
- Dual Chamber
- Sealed
