Re: Fuel Distributor, CIS vs CIS-e (need_a_VR6)
You mean the fuel distributor hasn't yet chosen to fall off the bunny, Paul?
The KS system is independent of the fuel distributor--you can install it on a CIS car without changing over to CIS-E. Looking @ Bentley, the CIS and CIS-E units are pretty different, in terms of the fuel distributor heads.(CIS-E has the Differential Pressure Regulator)..but you're concerned more about the airflow sensor unit. Looks to me like the CIS-E unit is also different, but I can't remember if the CIS units have a potentiometer in them or not?
If the CIS fuel distributor head will mount to the CIS-E sensor plate you might be able to make it work.
