  • Rejoining the VWVortex Community - Please review the following thread: Here
1 - 3 of 3 Posts
Discussion Starter #1
This has happened twice...
While driving the car will not do anything when I press the gas pedal starts to shudder and then shuts off. It happened again yesterday when I was on the motorway (interstate) at 80mph. I pulled off the road, took the key out of the ignition, waited about a minute and the car started right up. The CEL was on, I got home and this is the fault codes that VCDS found.
Does anyone have any ideas what the problem may be? I have my suspicions but I am no motor head so I need some good advice.
VCDS report:
VCDS Version: Release 805.4
Data version: 20090602
mine
Sunday,23,August,2009,07:26:37:09938
Chassis Type: 3C0
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62
65 6D 72 76
VIN: WVWCU73C07E013263 Mileage: 47270km/29372miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
6D-Trunk Elect. -- Status: Cannot be reached 1100
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 997 033 N HW: Hardware No
Component: P3.6-FSI-LEV2 G00 2371
Revision: --H11--- Serial number: VWZCZ000000000
Coding: 0000075
Shop #: WSC 05311 000 00000
2 Faults Found:
009529 - Low Pressure Fuel Sensor (G410): Open Circuit
P2539 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 4
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
Temperature: 19.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.811 V
004767 - Low-Pressure Fuel Pressure Regulation: Pressure too High
P129F - 001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 2
Mileage: 47248 km
Time Indication: 0
Date: 2009.08.22
Time: 12:14:56
Freeze Frame:
RPM: 1545 /min
Load: 31.4 %
Speed: 76.0 km/h
Temperature: 85.0°C
Temperature: 33.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.462 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 HK HW: 09G 927 750 FR
Component: AQ 250 6F 1271
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 25428 444 57477
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667520992
Coding: 0046541
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005704005
Coding: F504860700041500070A00000F000000000959435C0000
Part No: 3C1 955 119
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 25428
Part No: 1K0 955 559 T
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 25428
1 Fault Found:
00317 - Rear Lid Control Module (J605)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 145
Mileage: 39102 km
Time Indication: 0
Date: 2009.02.14
Time: 08:44:00
Freeze Frame:
ON
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F1024927
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 119
Mileage: 39731 km
Time Indication: 0
Date: 2009.03.03
Time: 08:35:09
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0P AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P93EP7D
Coding: 0012368
Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Address 16: Steering wheel Labels: 3C0-953-549.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507P
Coding: 0002211
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 A HW: 3C0 920 971 A
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007205
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 242
Mileage: 37140 km
Time Indication: 0
Date: 2009.01.01
Time: 16:25:26
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C065180152
Coding: 3FFD1F0CD31002
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 39467 km
Time Indication: 0
Date: 2009.02.25
Time: 15:32:12
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00005000 Serial number: 1166279TNVYZ04
Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
Part No SW: 3C0 959 433 AA HW: 3C0 959 433 AA
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 25428 444 85788
Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 C HW: 3C0 959 760 C
Component: Sitzverstellung 1001
Revision: 00004000 Serial number: 00000000000000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1123
Revision: 11007001 Serial number: 00000096168910
Coding: 0001463
Shop #: WSC 25807 128 68113
1 Fault Found:
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 2
Reset counter: 184
Mileage: 46861 km
Time Indication: 0
Date: 2009.08.13
Time: 06:08:01
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels: 3C0-959-433-46.lbl
Component: KSG PQ46 RDK 051 0218
Coding: 13916080018680120004151DF0CA8F0A085800
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1123
Revision: 11007001 Serial number: 00000004668911
Coding: 0001462
1 Fault Found:
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 184
Mileage: 46861 km
Time Indication: 0
Date: 2009.08.13
Time: 06:08:01
Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
Shop #: WSC 131071 1023 2097151
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio PM6 165 0035
Revision: 00165000 Serial number: VWZ5Z7F2076583
Coding: 0040401
Shop #: WSC 05314 000 00000
3 Faults Found:
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 39102 km
Time Indication: 0
Date: 2009.02.14
Time: 08:46:14
00875 - Treble Speaker Front Right (R22)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 39102 km
Time Indication: 0
Date: 2009.02.14
Time: 08:46:14
00877 - Treble Speaker Rear Right (R16)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 39102 km
Time Indication: 0
Date: 2009.02.14
Time: 08:46:14
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1109
Revision: 12005001 Serial number: 00000000029663
Coding: 0001168
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0420
Coding: 0100101
Address 6D: Trunk Elect.
Cannot be reached
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1109
Revision: 12005001 Serial number: 00000000017064
Coding: 0001168
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930613309982
Coding: 0001114
End ---------------------------------------------------------------------
P129F Low fuel Pressure... I had that code. My CEL turned on but the car ran fine. VW replaced my FUEL PRESSURE Sensore ... then a few months later it was replaced again due to a recal. I would call the dealership and give them ur VIN to see if you need this recall for the new FUEL Pressure sensore.
OH my passat is a 2.0T but VW might use the same FUEL pressure sensore for both engine..
JT
Modified by x9t at 12:32 AM 8-23-2009
Discussion Starter #3
Re: (x9t)
Thats what I was thinking it is. The sad thing is since I bought my car in the US and I now live in the UK the dealer here says that they cannot warranty anything on it. I have to pay for it myself, hopefully its not too much.
Thank you
1 - 3 of 3 Posts
