So I recently did my timing belt job and everything looks on point with the belt. BUT when I put it all back together the marking on the fuel send and receiving lines were mixed up and I tried starting her up. Did it a couple of times and then went online to look at pics for reference and i saw that they were mixed up. So I put it all on the right way and tried starting her up, there was a little hesitation and some back fire but she started up. Let it run for around 5 minutes then went on a small drive to see how it felt and it felt good (about 1 mile). Got back to the house shut it off and then it was downhill from there.
Question :
Could it be the fuel pump that i messed up?
What problems would happen when doing the mistake i did?
(mixed up the lines)
Could I have messed up the fuel injectors some how?
Problems:
Backfires (really loud)
car will start on cold start and shut off after about minute and a half
After that it takes a whlie for it to kick on but it eventually will. and then i rev it up to about 3k rpms and it holds for seconds then cuts right off
The car primes when the key is turned.
Any input would be great, THANK YOU
Modified by JRVDuBMK4 at 8:55 AM 3-22-2010
Question :
Problems:
