1 - 3 of 3 Posts
Discussion Starter #1
hey my 86 gli keeps blowing the fuel pump fuse when i drive down the road. it runs and idles fine but as soon as i put load on it blows the fuse. could this be a fuel pump? relay? or wiring issue any hel;p would be greatly appreciated. thank you
That fuel pump fuse also serves as the fuse for your o2 sensor. See if your o2 wiring is intact.
Discussion Starter #3
Thanks for the info I was actually playing around with my o2 sensor wire because It is rubbing on my heat shield so it may be blowing the fuse.
1 - 3 of 3 Posts
