Re: fuel pump (mattglxvr6)
Quote, originally posted by mattglxvr6 » |
when you shut the car off the fuel pump keeps run I have to disconnect the bat everytime i park it. |
Does the fuel pump start running when you reconnect the battery? If so, someone has removed the fuel pump relay and installed a jumper wire in its place.
If the fuel pump does not run when you reconnect the battery, then the fuel pump relay is faulty as this relay is picked by "pulses" from terminal #1 of the coil.
Consequently when the engine is turned off, the pulses from the coil stop and the relay opens up to cut off the +12VDC to the fuel pump.
Cheers, WWR.
