Re: fuel question?? (kaninchen)
you should be ok as long as your tank is in good shape. Your tank drains out of the bottom. the G60 in-tank pump is actually a lift pump, It pumps against gravity so that the main pump is unstressed and does not have to pump the gas against gravity(out the top of the tank). Use the lower pressure G60 main pump.
