1 - 5 of 5 Posts
RWD diesel Camry, AWD lifted Prius
the return line off of the dpr is leaking enough to smell while driving and leave a nice moist spot below it. is there any way to rig this for like a day until i can get the new line?
Re: fuel return line leak (Samson)
Is it the banjo fitting that's leaking? If so, take it off, turn the washers over and reassemble. You might get lucky... http://****************.com/smile/emthup.gif
Discussion Starter · #4 ·
Re: fuel return line leak (VWhombre)
no, its where the hose connects to the metal screw-on end. i put a hose clamp on to try to seal it, but it didnt help. thanks though
youll probaby just have to get another line...not sure how they attach the metal fitting to the return line hose, but my be is that even if you can just put another fitting on there that you wont have a hose long enough when you cut off the old line...i know my return line barely reaches pressure regulator...
1 - 5 of 5 Posts
