I am a new owner to a 88mkII Scirocco 16v. When I bought it and drove around and even hauled it across the country there were no hints of any fuel. I was told the gauge was reading a little low. I wasn’t sure what the fuel level was so a day after I got it home I took it out and “filled” the tank.
By filled I mean I pumped about 8 gallons in and stopped when it sounded like it was getting full. The Pump cutoff never kicked in and there was not a drop spilled or over flow. None from the fill and none underneath.
Now I am smelling fuel vapor outside of the car. It seems to be toward the rear. But it is consistent. No leaks, not a drop on the ground. Is there some vent or any reason you can point me to that would be causing this?
