1 - 20 of 138 Posts
Full modified haldex 20vT 1991 Golf restoration
Starting this little build thread for more of a progress thread and help others with any questions of syncro/haldex swap as i learn on the way..
here is the car the first day i picked it up from a buddy of mine.. was a big turbo vr6 swap previously to me acquiring it..
Jumped right into stripping the car down for its rust repair on the floor along with fixing the engine bay.. which meant removing the frame rail caps ( i really enjoy the look of the stock frame rails) fixing some of the patch jobs the previous owner did along with making sure everything was smooth and straight
Started to remove all the seam sealer on the bottom of the floors after building this tip over jig with a couple buddies.. everyone doubted my engineering :laugh::laugh:
Once all the seam sealer was removed i found more and more rust :banghead::banged: Crazy how much that crap hides!!
Started to cut out the mk2 exhaust tunnel
Mk3 tunnel is in! now i have a lot more room for the driveshaft and exhaust !!
Fast forward a bit and all the floors are rust free and patched, Started out with a rust Encapsulator then went over every seam that i touched with seam sealer to make sure everything was air/water tight
computer died last night.. time to update some more :p:p
More rust repair once i saw this after pulling the rear bumper off
After pulling off the outside panel turned out to be worse then i thought.. (always seems to be :mad::mad:)
bent up this piece to replace the rot!
The Patch panels :cool::cool:
Took some time away from fixing the rust and started to make my engine block look new again... And cleaned/ test fitted all turbo setup/ transmission
Ended up using por15 engine enamel on the block.. stuff works GREAT:thumbup::thumbup:
Prepping for paint
TEST FIT!!! :cool::cool:
Its gonna be a tight fit but looks like everything will work! I am going to vband the lower side of the downpipe so that should give me a bit more room but not much :laugh::laugh:
I know a lot of these photos don't really go in order, Making this thread kind of mid build :laugh::laugh:
Shaved a bunch of things that i don't need/want
Front driverside wiper hole... Going with a bonrath setup
rear bumper exhaust cutout and toe hook flap
Rear badge going bye bye
Test fitted the syncro beam along with cutting out the spare tire well for clearance for the differential
Also wanted to see how some of my chrome goodies looking on the white/black combo
Holy holy holy moly. So in for more. Your got some serious skills man! Great work on the restore and rust repair
Discussion Starter · #11 ·
MORE UPDATES
RIV NUTED everything i could to get rid of the old stripped out course screws that are stock
Got some more back from chrome Brackets for seatbelts along with beauty washers for fenders, rear hatch striker
Had one of my buddies make me a sheetmetal timing cover which is in the process of getting platted :):)
for the most part i am caught up on the thread now.. now time for present updates :thumbup::thumbup:
Discussion Starter · #12 ·
THANK YOU!! i have learned a lot over the years... This car here was kind of my trial car
Parted this car out a little over a year ago which then i wanted to start something new, and put towards all the things i have learned from the old car to this car..:):)
Discussion Starter · #19 ·
Litle bit of an update
I had sometime this weekend to finish the engine to get it ready for color. :cool::cool:
Also started to smooth out the rear badge that i ended up getting rid of.. smoothing out some little dings on the driverside rear quarter
If all goes well it'll be all one color the first weekend of october :D:D
Discussion Starter · #20 ·
received my timing cover back from platting :D:D along with mounting my turbo! Damn this motor is really going to look sharp in the engine bay:heart::heart:
now back to prepping for paint :peace::peace::peace::peace:
1 - 20 of 138 Posts
