Re: G60 rebuild? (cakoelling)
Apparently gone out in what respect? If the cogged belt broke and it grenaded a hole in the charger, then yes, you will be sucking in the blown bits of metal. If its just spit a strip, then it will be in your IC piping somewhere, or in the silencer box. If it just doesn't put out boost, you should probably bypass it until you can afford a rebuilt or a rebuildable core and rebuild.
