1 - 7 of 7 Posts
Can this be done? Just swap the whole thing out and put new rings in. Will I end up with a decent comp ratio for 15psi of boost? Will I need to swap intermediate shaft? Or can I just use the rods and pistons from the G60?
Re: G60 rotating assembly ina a 1.8 16v block??????????? (TBT-PassatG60)
compression will be close to 6:1......
good for 50psi http://****************.com/smile/emthup.gif
Re: G60 rotating assembly ina a 1.8 16v block??????????? (Ottar. L)
can you be more specific as to which head your gonna be using ?, it'll go in fine , its just you can still use an 8v head and get the 8:1 c/r , or w/ the 16v like already said itll be like 6.5:1
Discussion Starter · #6 ·
Re: G60 rotating assembly ina a 1.8 16v block??????????? (SSj4G60)
It will be a 1.8L 16v head. should i change just the rods or the crank to keep a higher comp ratio?
Re: G60 rotating assembly ina a 1.8 16v block??????????? (smoovdub)
The 16v head has much bigger combustion chamber than the 8v
something like 46cc(16v) vs 28cc(8v) I think
1 - 7 of 7 Posts
