G60 turbo
958 Views 6 Replies 5 Participants Last post by  onequickg60
i knew a guy that had a 8v turbo that lasted like 2 days. would a g60 with a turbo have a similar result or should i just rebuild my g-lader.
Matthew
1 - 7 of 7 Posts
Re: G60 turbo (Vr6dubs)
rebuild the glader its only 675 at gruven auto werks
unless you want some real power then go with a stage 4 and a stage 4 HP kit
before you decide give more info.. for one why did the turbo go.. i've had my turbo motor for over a year and blew 1 motor and a few head gaskets for running improper fueling.. not the turbos fault.. a proper setup shouldn't have no probs.. just take your time and do your homework.. a turbo setup lasting only 2 days 9 out of 10 is installer or setup error.. theres more than bolting it on and taking off..
Re: G60 turbo (yello90g60)
turbos are nice when done right
but my car came with a charger it will keep a charger im just funny like that
Who had this turbo G60 in MN?
Re: G60 turbo (psi)
not a turbo g60, a turbo 8v. i believe that the guy that had it is putting a turbo g60 in a mk1 scirocco.
Matthew
See less See more
Re: G60 turbo (VWslut)
turbo g60 and turbo 8v there concept is about the same.. if set up wrong it will blow.. it all in tuning.. give some details on the engine that blew.. odds are if he blew it in 2 days he over boosted it.. if he did that motor and now he plans on doing a g60t he might want to do his homework.. or it;ll happen again..
1 - 7 of 7 Posts
