Please I have the same problem what's your problem solution
Please help what was your problem solution I have the same problem2002 Jetta 4 speed auto(not Tiptronic) 2.0L gas 110,000 miles
Code(s) in photo below taken from VCDS(VagCom). G68 sensor the best place to start? I know that might seem obvious but reading many replies in here is a bit confusing as to the G38, fluid level, ground wires, etc. Or go for ground check first, then G68? I'm assuming(hoping) the other fault codes are due to the G68?
Physical symptoms. Won't shift out of first until 4,000 rpm and will shift to 3rd only once unless you stop and either shut car off or shift into park and get going again. Will not ever shift into 4th. And it early downshifts just below 2,000 rpm.
