i just purchased a 92 cabby for my girelfriend and i got it home and noticed the fuel, water and tachometer are not working i pulled the cluster checked the plugs to no avail im kinda stumped any help would be appreciated . thanks.
-matt
-matt
Quote, originally posted by tolusina » |
All three gauges are powered from the voltage stabilizer's output. The "Voltage Stabilizer" is a three pin, 10.0 VDC voltage regulator mounted on the instrument cluster circuit board. |
Quote, originally posted by cabdash » |
The fix is to pull back the contacts and wrap a bit of electrical tape over the plastic. When you rewrap the contacts back over the tape, you will now notice that you'll get a tighter fit when you plug the male end into the female side. |
Quote, originally posted by berlintsi » |
i have a gauge cluster and harness for an 89 jetta are the plugs on the bottom of the harness the same? it seems like the cabby has a unique cluster plug? |
