1 - 3 of 3 Posts
*GermanAutoParts.com* Mk1 Jetta/Rabbit CV Axle Refurbish Kits Available for MOST Applications
We feel that refurbishing your original axle shaft with OE quality joint kits for Jetta or Rabbit/Golf is a higher quality alternative to aftermarket axle assemblies, yet is still cost effective. Our refurbish kits include Genuine VW/Loebro outer and Metelli brand inner joints, boots, grease and hardware required for installation.
***Fits LEFT or RIGHT side*** Higher quality option to aftermarket axles, replaces both inner and outer CV joints with OE quality new joints while retaining your original axle shaft.
Why spend the additional time and money to refurbish your original axles with OE quality joints? Two reasons: First, the Metelli CV joints are higher quality than those supplied on aftermarket axle assemblies. Second, you will retain your original vehicle-specific axle shaft. Aftermarket axle assemblies use a generic solid axle shaft, while many OE axles use a large diameter tubular or solid/tubular design. You will be better off with your original axle shafts.
Whether you decide to refurbish your original axle with our joints kits or install an aftermarket axle assembly, you’re going to have the old axle out of the car either way. We highly recommend the refurbishing kit. Yes, you will spend a little extra time and get a little greasier (hint: we sell rubber gloves), but the end result will run smoother and last longer than an aftermarket axle assembly.
*If your original axle shaft is bent or otherwise damaged, refurbishing it is obviously not appropriate.
**Metelli joints are made to OE specs and are designed to be exact fit replacements on original equipment shafts. If your car has aftermarket axles in it now we cannot guarantee compatibility or performance on aftermarket shafts.
*** Available for most applications. Consult our website for complete application listing for this kit.
About Metelli
Based in Cologne, Italy, Metelli was established in 1962 and has and has been manufacturing CV joints since 1991. Metelli joints are produced to OE precision tolerances and are properly heat treated and case hardened as OE to provide a long service life.​
78rabbit1.5LGP & 82rabbitpickup1.6DGC
looks beautiful
includes all the proper clamps and washers
specifically the toothed washer!
however
those axle bolts look suspicious
the threads and the shaft are not the same cross section diameter
1 - 3 of 3 Posts
