Hey,
when I bought my 2000 Beetle it was driving and nothing looked seriously wrong with it. It had a couple small coolant and vacuum leaks and other minor issues. I fixed all that and it really runs and performs well now.
The AC and the heat were not working. The heat blew only lukewarm air. Before the winter came, I followed this video. I took the dash partly apart to get to the blend door.
I taped the holes in the blend door and the heat is now blowing real nice hot air. After that was such a success, I want to fix the AC now for the next summer
When I press the AC switch, the light in the switch will come on. The fans will start turning, but the AC clutch will not engange.
I charged the AC system around half a year ago and replaced the AC pressure switch and this time.
I found this video and followed the instructions.
It is not easy to test the wires while the module is plugged in. I didn't do (2.) and didn't test the four pin connector. The fans are running so there should be power.
So far I progressed to number (8.) from the videos instructions. My results are:
1.9 V on pin 2.
12 V on pin 4.
pin 6 not tested yet
11.6 V to pin 8
11.8 V to pin 9
alternating voltage on pin 13, it changes quickly and I can see 4 V, 8V, 5 V on the display in rapid succession
The video tells me to verify approximately 70 % duty cycle on pin 2. What does that mean? Are 1.9 V 70 % duty cycle?
My willingness to lie further under the car and mess with those wires is gone for today and I will perform further tests tomorrow.
Maybe somebody has already some answers for my questions and maybe some further hints on how to get the AC running.
I performed above tests with the iginition on, but the engine not running - is that okay or does the engine have to run?
1.9 V on pin 2.
12 V on pin 4.
11.6 V to pin 8
11.8 V to pin 9
