What i have.
1998 OBDII 2.0l
2* G60 Injectors
SDS EIC
TD Turbo w/diesel manifold @ 10PSI
Stock compression
No chip
OEM Spark plugs.
Is the OBDII not as strongly built as the obd1 and has issues with 10lbs on stock compression?
Im definately running rich, i've tried to give it as much fuel as possible but it still pings under wide open throttle at higher rpm like 4000+rpm. Im running stock plugs/wires..but i doubt changing those to a step colder would stop knocking would it?
im at a loss at this point
Modified by Doolie at 3:45 PM 9-13-2005
1998 OBDII 2.0l
2* G60 Injectors
SDS EIC
Stock compression
No chip
OEM Spark plugs.
