giac aww v.4 versus v.10 graphs
920 Views 15 Replies 5 Participants Last post by  PatAWW01
here's the graph. raw numbers in a few...
See less See more
1 - 16 of 16 Posts
Re: giac aww v.4 versus v.10 graphs (John A)
peak i picked up 1hp and 3ft/lbs, which is negligable...
at 2500 rpm, i picked up 9ft/lbs...
at 3500 rpm, i picked up 7ft/lbs and 6hp
at 4500 rpm, i picked up 11ft/lbs and 8hp
at 6000 rpm, i picked up 3ft/lbs and 6hp
sounds good to me!
See less See more
Looks promising I may have to start thinking about upgrading. How is the drivability of the new chip ?
Re: giac aww v.4 versus v.10 graphs (paulybumps)
feels great to me, i haven't noticed any surging or anything else. it feels smoother, but still pulls...
wanna swap chips
just curious to see if your chip does the same pat's v10 does.
See less See more
Re: giac aww v.4 versus v.10 graphs (beetle and gti 1.8t lover)
i might be around this weekend, will see what i can swing... sounds like you guys are having like the opposite luck that i am..
cool let me know..
They are gonna do the same thing Rich, every file is the same for DL ECU codes. I can't believe you and Pat think v.04 has a stronger mid range and is peaky, mine just rips no drops off. Some surging but the same as 4 and I can cae less about that stuff
Mike
Re: giac aww v.4 versus v.10 graphs (VWMike81)
It doesn't hurt just to try anyways..
See less See more
yeah, i was talking to someone earlier today and said i thought it had better midrange... certainly looks like this confirmed it, at least in my application
plan on logging requested / actual today.... do people prefer i run up through the gears, or just do a 3rd gear 1100-redline run?
John, I would like to see that 1100 run. also I wondered, on those graphs, hw low did you tuly start? I notice the hesitation pretty much anywhere I start. damn I need a Vag Com
Re: giac aww v.4 versus v.10 graphs (PatAWW01)
on the new (v.10) run, I pulled over on the parkway, and then took off REAL slow in 1st, hit 3rd, and punched it from like 1100rpm all the way to redline... when i did the v.4 run earlier in the week, i started off at like 1400rpm...
will try to log boost tonight...
3
john, yuo are a maniac
pulling over on the sie of the parkway
the hings you will do to help out fellow Du guys
See less See more
i'm waiting for a cop to pull up as i'm pulled over waiting for a big enough break to take off all slow...
'no sir, my car... um... nevermind'
lol, they'd never understand.......
1 - 16 of 16 Posts
