1 - 4 of 4 Posts
1997 Passat TDI
Got a 30 foot house trailer frame with three axles under it. It's mostly been sitting unused on our farm for the last 30 years or so and I need something to haul cars with. My general plan is to shorten it by at least 5 feet, dovetail it 10-12 feet, lower the axles by mounting them on the top side of the springs, put on smaller diameter tires, build some ramps and make it a gooseneck. Then there's the smaller things like wiring on some lights, the electric brakes, and some paint. I'll probably just weld on sheet metal for a deck.
Any tips?
Plant Tree Wood Wheel Grass
Wood Grass Trunk Gas Plant
Plant Table Wood Grass Wood stain
Wood Grass Groundcover Gas Plant
I’d assume the bearings are shot. Or at least may be dry/ need new grease? Otherwise not sure…..seems like a lot of weight to pull with the frame alone but perhaps you have a RAM truck with the Cummins engine?
I grew up on a farm too, one of the first things I learned was how to weld….
1997 Passat TDI
Definitely going to be doing some maintenance on the axles. I might even drop one entirely, I don't foresee needing three for anything. But you're right, it's definitely a lot of weight just on the trailer itself.
In the photos it was hooked to my '89 D350 5 speed Cummins. A couple years back I sold the truck to my dad and bought a '99 2500 V10 5sp 4wd. Apparently it's the same running gear as the Cummins, just with the V10 engine. Dana 80 rear. I liked the Cummins but I needed an extended cab, 4x4, and air conditioning. :p
1997 Passat TDI
Discussion Starter · #4 ·
It looks like most car trailers don't even have springs under them because the load itself has springs. It would definitely make my job a lot easier if I didn't even mess around with springs and brackets, I can just cut the drops off the ends of the axles and mount them straight onto the frame. It would get me lower to the ground that way also.
1 - 4 of 4 Posts
