Status
Not open for further replies.
1 - 7 of 7 Posts
GFB DV+ Diverter valve (part number T9351) is a direct replacement for the factory valve on late model VAG and Euro applications with a 2.0T TSI and FSI engine (Patent Pending). Keep what works and replace what doesn't! This Direct fit replacement for factory solenoid with TMS advantage. Works with stock hardware, improves performance and reliability. Exclusive pilot activation system allows HIGHER boostpressure. The end result is sharper throttle response, lightning-fast valve actuation, and the ability to hold as much boost as you can throw at it.
The OE solenoid itself is great- the ECU opens it faster than any pneumatic valve so why replace it? The only valve on the market to solve the problem without flutter, excessive cabling and extra parts, installed in half the time at more than half the price. GFB have Australia's best performance turbo management solutions
GFB's DV+ range is designed as a direct bolt-on replacement solution for problematic factory recirculating diverter valves. Not only do DV+ valves eliminate failure issues from high temperature and boost pressure, they also offer the TMS advantage of improved throttle response and boost holding.
  • Retains the factory solenoid coil for seamless integration
  • Replaces plastic valve parts with metal for reliability and strength on chipped engines
  • Exclusive “pilot-actuated” valve mechanism for rapid response at high boost
  • GFB expands the DV+ range with a direct-fit solution for the weak factory diverter valve used on many European vehicles.
The solenoid coil itself from the factory-fitted valve is great (the ECU opens it faster than any pneumatic valve so why replace it?), but the weak point however is the valve mechanism itself. So GFB's DV+ solves this problem by replacing just the valve parts with an anodised billet aluminium housing fitted with a brass piston machined to exacting tolerances.
The end result is sharper throttle response, lightning-fast valve actuation, and it will hold as much boost as you can throw at it.
Interested in purchasing this and other great products? - BUY HERE!
Discussion Starter · #2 ·
This is a relatively inexpensive, yet very beneficial modification you can make to your 2.0T TSI/FSI. This product has amazing OEM like fitment.
Discussion Starter · #7 ·
Launching a new promo for these!
Any of these sold will receive an HS Tuning T-Shirt, (S, M, L, XL, XXL) and Vinyl Decals for their car (White, Black, Metal) - Please specify at checkout!
1 - 7 of 7 Posts
Status
