The DIY thread, bigger and better!!!
Let me know if pics stop working in a thread, if a link is broken or sending you to the wrong place.
You're encouraged to post links to any DIY.
I am in no way held responsible for any damage caused by the use of these DIY's, USE AT OWN RISK! I also did not make all these DIY's. Have fun!
Table of contents
Interior
Dash & center console
Doorcards, headliner & general upholstering
Gauge cluster
Heating
Interior lighting
Seats
Sunroof
Water leaks
Other stuff
- Holistah's original DIY thread
- Official MK2 forum FAQ
- Old MK2 FAQ/DIY thread
- AA1Car Automotive Repair & Diagnostic Help
- A2 Ressource
- Most ghetto fix thread Because not all DIYs are good
- The Definitive Cheap A$$ Build Up LOTS of free/cheap tuning tricks
- How to use the Vortex SEARCH function, tips & tricks
Table of contents
- Interior
- Exterior & lighting
- Engine & engine bay
- Brakes, steering, suspension, wheels, tires & transmission
- Miscellaneous & online parts links
Interior
- Blower motor resistor fix
- Dash emoval
- Corrado dash swap 1
- MK3 dash swap 1
- MK3 dash swap 2 Dead pics
- Mk3 center console mod 1
- MK3 center console mod 2
- Ford Taurus cupholder mod
- Cupholder Mod
- Center console stereo install
- Working blank/dummy switch
- Dash blank/dummy voltage meter
- Custom Ipod bezel mount
- Custom shifter frame
- MK4 shifter & boot
- Headliner reupholstering 1
- Headliner reupholstering 2 Dead pics
- Headliner reupholstering 3 Dead pics
- Headliner reupholstering 4
- Headliner clips
- Golf headliner in a Jetta
- Complete re-do of door cards Dead Pics
- Door cards reupholstering
- Rear parcel shelf and speaker tray carpeting Dead pics
- Custom made rear parcel shelf
- Door speaker mod
- Reinforcing door speaker grilles
Gauge cluster
- Gauge cluster removal
- Odometer fix
- Custom gauge faces
- Gauge cluster lighting
- Gauge cluster LED 1
- Gauge cluster LED 2
- Digifiz gauge cluster info 1
- Digifiz gauge cluster info 2
- Digifiz gauge cluster info 3
- Gasser tach conversion to diesel tach
- Changing the clock from 24h to 12h
Heating
- Heater core replacement 1
- Heater core replacement 2
- Heater core replacement 3
- Heater core replacement 4 Very funny read
- Heater box blend door foam fix
Interior lighting
- Heater controls LED 1
- Heater controls LED 2 Dead pics
- Heater controls LED 3
- Heater controls illuminated siders
- Headlight switch LED
- LED panel dome light
Seats
- Recaro bottom support fix 1
- Recaro bottom support fix 2
- Recaro bottom support fix 3
- Recaro side bolster replacement
- Recaro restoration
- Recaro disassembly/reassembly
- Self reclining Recaro fix 1
- Self reclining Recaro fix 2
- Leather seat re-dying 1
- Leather seat re-dying 2
- MK3 seat swap
- MK4 seat swap
- New Beetle seat swap
- Seat fabric repair
- Corrado rear seat install
Sunroof
- Electric sunroof mod 1 Dead pics
- Electric sunroof mod 2
- Electric sunroof mod 3
- Tilt and slide sunroof
Water leaks
Other stuff
- Ignition switch replacement
- Removing the lock cylinder from the ignition housing
- Three point seatbelt swap
- Big spline steering wheel adapter removal
- Steering wheel turn signal tab fix
- OEM steering wheels that fit MK2's
- CE2 wiring harness info
- Opening stuck rear door
- Grip tape pedals
- Ignition lock rekey
- DIY remote locking system
- Ipod only audio (no head unit)
- Fiberglass sub box
- Noise reduction
