I am using the Liqui Moly 5W40 Leichtlauf High Tech...there is the Castrol Edge stuff for half the price right now...might do that.
Forget about the weight, just make sure it has the proper VW approval so 504. If it does not say it, it is not approved. Does it also say 502 in your manual (this gives you a few more options), my 2018 has both 502 and 504 as approved oils.I’ve decided to go with 0w 30 synthetic oil. Mobil 1 makes one for a reasonable price in a 5 qt jug. However, I don’t see anywhere that it has VW 504 00 certification/standard. I’ve used Mobil 1 for years. It relatively cheap compared to Motul. Does it matter if it‘s not officially VW 504 00?
This is basically the sticker I have in my 2016 Golf R.2015
Yep! $60 on Amazon for a 6pack.Mobil does have a 0w30 and 504.00 approved oil, it is ESP X1 0w30. It's harder to find though.
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1-esp
Advanced Fuel Economy 0w30 does not met the engine sticker requirement as it is 0w30 AND 504.00
Mobil does have a 0w30 and 504.00 approved oil, it is ESP X1 0w30. It's harder to find though.Thanks for the feedback. Do any of you have this sticker in your engine compartment?
I have a 6 pack of this M1 ESP in my oil stash and plan to use it this late Fall.Mobil does have a 0w30 and 504.00 approved oil, it is ESP X1 0w30. It's harder to find though.
And yet M1 ESP FORMULA 0W40 is the recommended oil for Corvettes having I]only [/I]the dexos2 certification i.e. not 502 (or any other). Weird eh?Mobil 1 0W-40 here, meets the 502 spec
Not really weird, since certifications are things that need to be applied for and tested. M1 has a European Formula 0W-40, which has the 502 approval.And yet M1 ESP FORMULA 0W40 is the recommended oil for Corvettes having I]only [/I]the dexos2 certification i.e. not 502 (or any other). Weird eh?
https://mobiloil.com/~/media/amer/us/pvl/files/pdfs/em%20sga%20-%20corvette%20mobil%201%20esp%20formula%200w-40%20one%20pager.pdf
The Afton Oil Specification Handbook is the only publicly available resource I have found for consumers to know what the OEM oil specifications actually mean (https://www.aftonchemical.com/Insights-and-Resources/Documents/Specification-Handbook please rate it as helpful and thank them and ask for an update, no other company is willing to share this info).my 2018 R also says only use oil that compiles with 0w30 & 304.00 spec...
This is weird, the oil filler cap says Castrol, the oil sticker says use 0w-30 & 504.00 oil, and yet Castrol don't even make oil that compiles with both. Their 304.00 oils are 5w-30, their 0w-30 oils are 502.00.
also found a high res picture of NAR 2019 golf R engine bay, as you can see, it says 502.00 or 504.00. weight is not even specified.
So we have
2015 & 2016 sticker: use 502.00
2018 sticker: use 502.00 OR 504.00
2019 sticker: use 0w-30 AND 504.00
any one got 2017 sticker they want to share??
Extremely good link, thank you!The Afton Oil Specification Handbook is the only publicly available resource I have found for consumers to know what the OEM oil specifications actually mean (https://www.aftonchemical.com/Insights-and-Resources/Documents/Specification-Handbook please rate it as helpful and thank them and ask for an update, no other company is willing to share this info).
VW 502 and 504 specify what viscosity grades are allowed to meet those specs.
So we have
2018 sticker: use 0w-30 AND 504.00
2019 sticker: use 502.00 OR 504.00
And which vehicles do they use it for? You do know that VW has sold vehicles before 2019 right?I went to my local dealer and a service tech told me they use Castrol edge professional OE 5W-40. This oil is VW 501 01/502 00/505 00 based on my research.
Yah my engine bay has the same sticker... i checked the Castrol Canadian website and it recommended either the 5W-30 C3 or 5W-40.My engine bay has the sticker with the 0w30 and 504 yet the intervals on the Canadian website for my car indicate 5w40 and 502...
I personally use the Castrol 0W-40 that meets the VW 502 spec. Per the Bob is the Oil Guy forums, it’s one of the best oils out there and is available at a great price from Wal-Mart, at ~$25 per 5qt jug. I’d use this oil in any VW and not think twice.
Note - I would only use a 504 oil if I did regular oil analysis to determine when the oil needs to be changed, since 504 oils are designed for markets with low-sulfur gas and the US doesn’t yet mandate the use of low-sulfur gas. The 504 oils will not last for extended drain intervals (>5000 miles).
Sent from my iPad using Tapatalk[/QUO
One of the best oils? It's a blend of about 50% synthetic and 50% fossil oil so how does it qualify?
And VW specifies 10,000 mile oil change intervals for oil that doesn't protect for more than 5,000 miles?
