Year:2018
Make:Volkswagen
Model:Golf R
Mileage:19500 M
Transmission:Manual
Engine:N/A
Trim:N/A
2018 Mk7.5 Golf R
Gray
WVWWF7AU5JW271959
ENGINE/SOFTWARE
-Accessport,
-AMS Outlet pipe
-GFB DV+ turbo diverter valve
-Modified stock air guild
OIL/TEMP MANAGEMENT:
-Aibed Oil Cooler gallery with custom lines 180F T-stat (AR Motorsports installed)
-Setrab 25row, 6-series core
-CSF aux core cooler
SUSPENSION
-Front-
-Lower control arm bushings TTRS (solid rubber, new ball joint)
-Otherwise stock DCC
-Rear-
-034 trailing arms
CHASSIS
-034 front subframe lockdown (upper and lower)
-ECS rear lower subframe inserts
-034 dogbone full puck, arm and lower insert
-OE splash shield
-AreoFabb V2 front splitter
-Blaze carbon fender guards
-Full front, rocker and other places paint protection film (PDX Wraps)
DRIVELINE:
-Southbend Stg III Daily, 11,5k,
-034 rear main seal, 11,5k,
-SS clutch line
-Spulen clutch bleeder block
-Torque Solution shifter cable ends
BRAKES:
-Stock brakes F/R
-SS Lines, F/R
WHEELS/TIRES
-OE 19” wheels with snow tires
-OE summer tires
Wheel Tire Automotive tail & brake light Vehicle Car
Car Tire Automotive tail & brake light Wheel Vehicle
Wheel Tire Car Vehicle Automotive tire
Tire Wheel Car Vehicle Motor vehicle
Wheel Tire Car Vehicle Hood
Wheel Tire Land vehicle Car Vehicle
Vehicle registration plate Wheel Vehicle Grille Car
Wheel Car Tire Vehicle Grille
Hood Motor vehicle Vehicle Automotive design Car
Car Wheel Tire Vehicle Automotive tire
