Hello,
I have a immo fault, I didn't erase it with vcds. What can I do? Do you have any suggestion?
Thanks for answering.
My car result: (2008 Golf V 1.4 tsi)
Saturday,05,June,2010,19:41:41:14251
VCDS Version: Release 908.2
Data version: 20100326
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ8P109144 Mileage: 56600km/35169miles
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine Labels: 03C-906-032-BLG.lbl
Part No SW: 03C 906 032 Q HW: 03C 906 032 C
Component: MED17.5.1 G 2315
Revision: 96H07--- Serial number: VWX7Z0H23N57Z2
Coding: 0000072
Shop #: WSC 00191 264 15243
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-614-517-MK60-F.lbl
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H14001
Coding: 0035458
Shop #: WSC 00606 389 97262
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DD HW: 1K0 907 044 DD
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005514647
Coding: E58D0F270004150147140000140000000009FF075C00010C000000000000
Shop #: WSC 00028 028 00001
Part No: 1K1 955 119 E
Component: Wischer 230208 021 0501
Coding: 00038805
Shop #: WSC 00028
Part No: 1K0 955 559 AF
Component: RLS 110308 046 0204
Coding: 00471077
Shop #: WSC 00028
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0006
Revision: -------- Serial number: 66640920409441
Coding: 100001
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1UZSS%
Coding: 0013111
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 051 0100
Coding: 0002022
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 874 G HW: 1K0 920 874 G
Component: KOMBIINSTRUMENT VDD 1215
Revision: V0002000 Serial number: VWX7Z0H23N57Z2
Coding: 0003103
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 260208F1000290
Coding: E9A07F06000202000002
Shop #: WSC 00611 389 98169
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 1215
Shop #: WSC 00611 389 97259
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Mileage: 53755 km
Time Indication: 0
Date: 2000.00.00
Time: 18:06:56
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 006 1219
Coding: 0000180
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 80900A005103487F6D020F0F60C8CF2A10FC00
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000436
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0130
Revision: 00000001 Serial number: VWZ1Z3I4208358
Coding: 0800040104
Shop #: WSC 01357 011 00200
1 Fault Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 123
Mileage: 56601 km
Time Indication: 0
Date: 2000.00.00
Time: 19:39:21
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0000144
Shop #: WSC 00028 028 1012545
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
End ---------------------------------------------------------------------
Chassis Type: 1K0
Coding: 0000072
Revision: 00H14001
Coding: 0035458
Coding: 00038805
Shop #: WSC 00028
Coding: 00471077
Shop #: WSC 00028
Coding: 100001
Coding: 0013111
Coding: 0002022
Coding: 0003103
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 53755 km
Time Indication: 0
Date: 2000.00.00
Time: 18:06:56
Coding: 0000180
Coding: 0000436
Coding: 0800040104
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 123
Mileage: 56601 km
Time Indication: 0
Date: 2000.00.00
Time: 19:39:21
Coding: 0000144
Coding: 0000144
