1 - 5 of 5 Posts
Banned
I recently purchased a PWR barrel type AWIC and am in the market for a pump to use with it. I found the following on ebay and hoping some one with experience can tell me if this is a good pick or not. It says to use this with a 10amp fuse, which seems excessive for an automotive application, do you think the stock alternator can hold up? Here is a link to the one I am talking about:
http://cgi.ebay.com/ebaymotors...=WDVW
Thanks.
Banned
So stock alternator should be fine driving this thing? 10amps seems excessive, but im guessing it doesnt draw that much it just needs to be fused that high.
Banned
Discussion Starter · #4 ·
The guy just got back to me and told me it says 8amps on the side of the pump, im gonna give it a try. thanks for the feedback FYGTBUG (awesome beetle btw http://****************.com/smile/emthup.gif)
Re: (vwtuning)
I run a gm 1 wire alt and run the pump off a switched 30amp relay, realistcally you only need the IC under boost, not all the time so maybe a microswitch that comes on when it see's boost?
Modified by FYGTBUG at 5:15 PM 5-18-2004
1 - 5 of 5 Posts
