Hello all. My name is Mario. I've been away from this site for a while as I've been without a VW for some time. This is my 3rd Cabriolet... and hopefully my last. I'm the 3rd owner of this car. She's considered to be a soft project... but really, time will tell.
Here she is in her new home!
She runs pretty good, except when cold. Previous owner had done quite a bit of work: Fuel relay, fuel filter, injectors, spark plugs, wires, Hall sending unit, Coil, O2 sensor, vacuum lines, timing belt, lifters, timing gears, accelerator cable, shocks, springs, engine mounts, shifting linkage bushings, full exhaust system and catalytic converter.
Aside from the rough idle while cold, the fuel filler neck will need immediate replacement. Planning on doing that along with a new gas tank as well, figure I'm dropping the tank anyways... might as well put new one in. Plus, given the state of the neck, who know what crud has made its way into the tank.
