1 - 19 of 19 Posts
Ok. So on the way into work, the mfa indicator went blank and some odd indicator lit up. It's not a check engine light, it looks different. It is a yellow warning light, looks almost like it's pointing to the gas cap. Anyway, this sucks
Also, the brake light doesn't light up anymore either when I pull up the e-brake.
Damn. I just spent mad loot on this car...
Well, the pdi guy at my dealership is looking into it...basically telling me that they don't have any info on my car just yet. I hope it's drivable...anyone know what the problem might be?
a picture is worth a thousand words
take a pic of the warning and post it so we can see (help) to identify it. If it's yellow (this is a good sign) as it's warning and not red. Also the image (might) be in the owners manual
Hope everything checks out ok
Discussion Starter · #4 ·
Re: a picture is worth a thousand words (TTigg)
I don't have a camera on me...it is located below where the low gas warning light would be. Wierd thing is...the brake light doesn't illuminate now when I pull the ebrake up.
Good to know it's a warning if yellow...the icon is not listed in the owners manual anywhere!
I just hope this isn't a bad omen...the pdi guy is telling me there is nothing in the system about the car...he's checking to see if it's a defective gas cap for now.
Re: a picture is worth a thousand words (Maddave10)
From what I can tell, it may be the cluster. From what I have beeb told, they are not gonna be available until they have produced all the cars.
Why me? I know I'm nit picking...but why me?
Re: Got my first problem today (Maddave10)
It means your gas cap or filler door is loose/open. Happened to me then went off after I retightened the cap. Good luck. http://****************.com/smile/emthup.gif
Re: Got my first problem today (gtiness)
Quote, originally posted by gtiness »
Just had my first problem today.
Left tail light is out
Weird...my left tail light went out about 2 days after delivery for me. Dealer said it was just a dead bulb.
I got the same indicator last night and it is in fact telling you that it thinks
your gas cap is open. In fact, my MFA was saying "Check Gas Cap"
(This condition used to actually cause a regular check engine light).
I double and triple checked it and my gas cap was closed securely.
I scanned it with VAG-COM and it showed a possible leak in the fuel
vapor return system (of which the gas cap is part of).
I cleared the code, and I'll see if the light comes back.
ian
Re: Got my first problem today (Daemon42)
This isn't just a VW issue. My Lexus did the same thing, but it was the "check engine" indicator. After removing and replacing the gas cap, the indicator would reset after a couple of restarts of the engine.
At least we know the system functions........and be glad we have a specific trouble light indicator for the "cause".
Re: Got my first problem today (gonebad)
Ian, can you direct me to more information about obtaining and using VAG-COM software to check codes.
Any info would be much appreciated
I had a cluster replaced on mine last Friday. I had to wait a little over a week for it - but my tech did a good job, No pain - no foul! All is good in R-32 land! Stuff happens, and I don't have "the fear" It is a car, and Jesus didn't build it - just some humans and robots!!!!
Re: Got my first problem today (kevin808)
Quote, originally posted by kevin808 »
http://www.ross-tech.com
Re: a picture is worth a thousand words (SERVICEMANGLER)
You guys are getting me real scared about my car... I dont take her over 3500 rpm.... I have about 750 miles on her...
Re: a picture is worth a thousand words (YodaDrivesAgti)
Oh go for it already.... Rev it up to 6k, it loves it! Hell, I love it.
P.S. Thanks for the link!
Shes My Prrrrrrrrrecious...
Ian. where can you buy a good VAG-COM? How is the code "cleared"? Do you use the VAG-COM to do it?
Re: Got my first problem today (vso)
TA This is where it can be purchased. Since the OBDII is a standardization of diagnostics, the codes should be standardized as well. I do not for sure. Contact ross tech and they would give you all the answers you need, I'm sure.
http://www.ross-tech.com/vag-com/
1 - 19 of 19 Posts
