Re: Got new heated leather seats, got some ?'s (MOMO Vento 96)
There is an absolutely
beautiful write-up for enabling heated seats in the Official DIY/FAQ thread at the top of this forum. I think it's on one of the first few pages of the thread. I followed this DIY step-by-step guide last year, and it went off without one hitch. http://****************.com/smile/emthup.gif
Quote, originally posted by MOMO Vento 96 » |
hooking up the heated seats is a PITA |
it really isn't.
running the wires isn't hard, just use a coat hanger and fish them through |
yeah, don't do that. using a coat hanger to fish wires in a car is a good way to set yourself up for a dash fire sometime down the road.
as for swapping the lock cylinders in the rear seats...that's not too bad either. If you take a good look at how the upholstery clips onto the seatbacks, you'll see how to undo those clips and pull back the leather (no need to unclip the wire from the foam...just let the leather flop there). Once you do that, you can reach in behind the foam and unhook the lock release lever and pull it out. Then the top face of the plastic part (the flat part you see, with the two holes in it) can be popped off the bottom part. The bottom part has the lock cylinder in it, and is held to the seatback frame by two screws. Remove those, remove the lock/latch, and you're ready to swap it with your old seat's lock.
It's involved, but it's certainly not hard.
