It took a few attempted, but i think i got the rear end together right. I am missing the jam nut above the spacer. But ill get to that soon.
Its CE2. Corrado (most likely) so yes. Unique left and right plugs.As to the headlight issue...
Remind me about the wiring for this car. Did it get a Corrado or MK2 fuse box and wiring?
If so, then left and right headlights are on separate circuits whereas a traditional MK1 would have headlights piggybacked.
With MK1 if you only have one side lit up, you know your problem is localized to that bucket that doesn't light.
With MK2, could be anything because different circuits and independent wiring.
If you have a later fuse box, you could rebuild it. Mine turned out to have corrosion and broken pins. The repair was epic. Or, they are available delivered from Werk34 for under $200 new FAW (China-Jetta). I have a NOS spare on hand.
