Hey everyone, figured id do an update. Corrugated plastic rad cover is working fine. I would recommend going with white/black if you can, and not paint it. Next time in at home depot, ill get another one. Only cost a few bucks.
Transmission has been fine. No problem at all. Next time the trans comes out, we will dig that gear out of there. TINY leak, so small its ignorable. So thats awesome.
Steering rack leak - has not been that bad at all. not enough to care to fix it yet. After we removed the pump/pressure. Much better. It just gravity feeds oil from the res.
Rad leak - After my buddy helped and we got the o-ring on it correctly. No leaks at all. Still feel dumb about that one lol. will NEVER make that mistake again, so thats something.
water Leaks - Ugh still fighting the pass side. I think I found the problem, its the door seal. Looks like its one from a 4 door, and too short/hella worn out. Not super expensive, so we will see. Looks like the rain is starting to slow down abit out here.
Seeing some better weather, so maybe ill get something done here soon.
Im thinking about getting the same setup
@mokoosh - with the column bearing part.
Lower Steering Column Bearing Retainer
using a zip tie helps, but it would be nice to have it supported better. Even if its a bit sketchy with the column collapse. Not like we are not at risk driving these tin cans as dailys anyways. I was thinking about using nylon bolts, so they can easily stretch and allow for it to collapse.
The mk3.5 cupholder works AMAZINGLY!!! like better than I expected. Totally worth grabbing one if you find it in a yard.
Don't think you can find anything better for under $5.
Next goals:
Deal with the front end. Tires/alignment/column bearing retainer.
Flush brake lines (still have not gotten around to that, oops)
Then hopefully tax money, new charger? + some new hand tools?
