1 - 10 of 10 Posts
I experience a grinding sound if i shift hard into second. It only happends if i am shifting at about 5000rpm, and aggresively down to second. I even have tried it with my clutch floored, so its not that i am letting up to early or not going down enough. Regular driving i dont experience it though. Any help?
Re: Grind into second (brandonp)
when it grinds does it feel like its a shorter distance bewteen where its in gear and its almost in (mine theres a bump then it goes in but sometimes the bump isnt there)
kinda sounds like a bad syncro
its a 2.0
It grinds before it actually slips into where it should be. And it only does it at hight revs and hard shift, if i do a softer shift and kind of let it slip into second it is ok. It's jsut scaring me.
Re: Grind into second (VentoVR614)
Quote, originally posted by VentoVR614 »
time to buy a new car. Its ruined the tranny should never do that.
My Vr used to do that ocasionally then one day the tranny fell out on the freeway and I ran it over.
jesus, thats like driving your car off a cliff, it wouldnt be worth **** after that.
Banned
Re: (Dan J Reed)
Quote, originally posted by Dan J Reed »
Change the fluid....
To some thing better:
(Oh crap my fav link is gone after the crash right now.
GM syncromesh tranny fluid
if it one good thing GM makes these days its Fluids
Re: Grind into second (joker22942)
It is a common problem in 020 trannys.
You can change the fluiid, it will not solve the problem though.
As long as you dont keep grinding it then it will be fine.
It is the syncro, So you just have to avoid driving hard in 1st to second.
So just take it easy in 1st gear and the shift to 2nd gear, then you can go crazy.
1 - 10 of 10 Posts
