Grinding Gears.
832 Views 18 Replies 13 Participants Last post by  VW1990CORRADO
Grinding Gears?
Hey guys,
I got a slight problem with my gear shifting. Everytime i put it in first gear fast, the car grinds, but its okay if I put it in slowly. I'm sure, i got the clutch all the way down. What can it be? Bad tranny? Clutch?
By the way its a G60 that i have.
[Modified by Piezo, 5:20 PM 2-8-2002]
[Modified by Piezo, 5:34 PM 2-8-2002]
1 - 19 of 19 Posts
Re: Grinding Gears? (Piezo)
Hello? Anyone have any idea whats wrong?
Are you trying to downshift into 1st ??
Is the car moving while you do such things? If so, either learn how to double clutch, or... stop.
-mark
Re: Grinding Gears? (92BlkSLC)
Its stopped at a light, the light turns green and i put it into first, the gears grind, but if i put it in to first slowly, it doesn't grind. It works fine when i downshift using heel and toe or double clutch. By slowly, i mean i shift it into neutral pause for a half a second then i shift it into first.
so any ideas?
Now may be a good time to flush and refill tranny fluid w/Redline MT90.
Re: Grinding Gears? (fahrfrumlosin)
Change your tranny fluid and check your linkage and you should be fine http://****************.com/smile/emthup.gif
See less See more
also, just watch for the yellow at the intersection and put it in first then
fluid change good idea, but sorry this is just me wasting bandwidth again http://****************.com/smile/emthdown.gif
See less See more
2
Re: Grinding Gears? (G60_Likes_2_Break)
oh thanks guys! Tranny fluid change it is!!!
Unless the trany shifts to 2-3-4-5 leave it and double clutch it in to first if you have to. I have a VR6 and if im at the lights waiting it will grind if I shove it in fast. Take is slow, then go fast!
See less See more
Re: Grinding Gears? (XGTiG60X)
1st gear doesn't have a synchro so fluid change and linkage adjustment is the way to go.
Re: Grinding Gears? (BadAssCorrado)
Change your tranny fluid, adjust your shift linkage, and if all else fails check your slave cylinder.
Corrado Dad
Re: Grinding Gears? (Corrado Dad)
never down shift to 1st. but get in the habit of going 2nd THEN 1st. it stops the mainshaft from spinning and u may never grind like that AGAIN. also good for reverse grinds. 2nd to 1st to reverse. just remember put it in 2nd first.
See less See more
Re: Grinding Gears? (VW1990CORRADO)
See less See more
2
I do the exact same thing, with shifting into 1st and for reverse. I have not grinded since. I have been doing that for about a year now, no problem!
See less See more
Not a VW, but if I put it in 1st gear at about 5mph when I'm almost to a complete stop. It slips right in like butter. If I wait until I completely stop its a little tougher to get into first. It has something to do with the speed of the transmission input shaft. This method of getting into first will vary based on the type of transmission.
Re: Grinding Gears? (Syruz)
mine grinds too...well ill shift, say, from 2nd then to first, but it still grinds if i am not going really slow or stopped, and then i still shift it slow. the tranny fluid was replace last year...is it just the linkage then?
quote:[HR][/HR]mine grinds too...well ill shift, say, from 2nd then to first, but it still grinds if i am not going really slow or stopped, and then i still shift it slow. the tranny fluid was replace last year...is it just the linkage then?[HR][/HR]​
you shoulsnt be shifting to 1st UNLESS youre stopped .
See less See more
1 - 19 of 19 Posts
