Rears look AMAZING!!! Where are the fronts?
The gauges look great too, very seamlessly integrated into the car. Flows perfectly.
Quote, originally posted by rollininstyle2004 » |
Rears look AMAZING!!! Where are the fronts? The gauges look great too, very seamlessly integrated into the car. Flows perfectly. |
Quote, originally posted by Grig85 » |
I have 2 questions tho. this is my first time ever dealing with air and I am a bit worried about the whole relay process. I wired it up right and I got 100-140 switch, 480cc, and a 5 gallon tank. How long does it take for tank to fill up? I would assume single 480cc is not capable of blowing up the tank but still its my first time and just wondering what if switch is bad ![]() ![]() here is what it looks like and I am sure many ppl used it, and can let me know the answer. ![]() |
Quote, originally posted by socal07rabbit » |
looks like you are applying the teflon tape backwards. If done properly, it won't back off when you thread the fittings in. Other than that, great job can't wait to see the finished product. |
Quote, originally posted by Rat4Life » |
Erik Bljaha gde obeshannie fotki? Where are the pics man? |
I am predicting control arms install to be the biggest bitch of the summer for me. |
Quote, originally posted by Mr Schmidt » |
I replaced all the control arms on my wagon earlier this year. make sure you have a propane torch or something similar when you remove the 2 upper arms. the bolt that goes through the spindle holding them in place are always a bitch to get out. Heat the f.cker up and and use a hammer to beat it through. use some copper grease when you put everything back together. this will save you some pain when you want to unbolt isht later on. |
