I’ve always wanted a GruppeM intake for my cars but never really got around to it because there were always less expensive alternatives. All of my friends have them on their Porsches and Ferrari’s etc. I didn’t realize they were made to order. I waited 12 weeks and finally received it. I must say this is a beautiful piece of art. I had the mk1 carbonio intake on my B5 A4 and loved it.
The carbon fiber is a nice weave and the quality of the clearcoat is perfect.
It has a velocity stack made of aluminum which we all know is the preferred design for intake systems.
all of the enclosed hardware is well packed and it uses a genuine K&N filter they had specifically designed for their kits. It also has the filter oil.
This small filter is for the secondary air pump which I don’t have.
Unfortunately I am not able to dyno the car before and after but the design has a better air funneling design than my carbon fiber moddshack tuning intake.
It comes with a foam tape for the filter element to secure tightly. It already has a rubber tape on one side from the factory. You just have to apply the other side yourself. This helps keep it an air tight fit.
This is where the edge of the carbon fiber meets onto.
The k&n filter has a smooth big nipple for airflow.
its a very tight fit and since I have the Badger5 full 3” silicone turbo inlet hose it sits higher. You can see it hits the battery cage. They include a foam tape for this so it doesn’t vibrate and eventually scratch the CF gel coat.
I’m sure if you have a stock inlet hose or samco it will fit perfectly. I couldn’t use the brackets because of this.
It has a rubber trim that pushes tightly to the inside of the engine bay. This was something added after their Mk1 version.
definitely a huge difference in sound from the moddshack intake. You can hear the air being sucked in a lot louder. I can hear that the air in the charge pipe has a higher pitch as well unless that’s the intake too. Can’t tell much of a difference on the butt dyno. It feels faster but that just could be psychological with the louder sounds. It seems to pick up faster but honestly again without a before and after dyno I can’t be sure. I’m definitely very happy with it. It’s difficult to hear the air but you can hear it. This intake system is a beautiful sculpture. On their website they say “All GruppeM products are handcrafted to order by experienced Artisans to ensure the highest quality.”
instagram.com
www.gruppemdirect.com
Login • Instagram
Welcome back to Instagram. Sign in to check out what your friends, family & interests have been capturing & sharing around the world.
AUDI | TT | 8N(A4) | 1998 ~ 2006 | 1.8 LITER ・QUATTRO・TURBO | RAM AIR SYSTEM | FRI-0171
This beautifully crafted high capacity RAM AIR SYSTEM makes full use of the engine bay drawing in the greatest amount of ambient air available. The carbon fiber filter case prevents heated air from entering intake stream lowering intake temperature increasing horsepower and torque throughout the...
