Hi!
Has anyone experimented with these turbos? For a personal project I am building a Golf Rallye and want to push around 450 crank HP (about the limit that the Syncro system can take). I will be modifying the gearbox and rear diff in the future so maybe budget a maximum HP of 550, but consider 450 for now...
I will be overboring to 1.9l, using aftermarket ECU, large FMIC with water spray - all on an AGU large port engine.
I know the GT's are ball bearing items, what kind of response are you seeing with these turbos? Considering I want to see a maximum of around 550HP at some point, would the 28 be a better option? I only see the 25 rated at 450HP on most websites (AR depending). Also, what AR's are you guys going for with an engine of this displacement? At what point is max torque achieved? Does it hold for the rest of the rev range as well?
The car will mainly be used for sprinting (drag strip) but will see occasional track use.
Anyone share any thoughts on their own setups?
Thanx...
Thanx...
