1 - 20 of 144 Posts
More items being added all the time, check back for more great finds! :D
*I realize all the pictures are down, I have the orignal and more recent pictures of all the items on my computer, just send me a PM and I can email you whatever you would like to see*
I have a bunch of odds and ends for sale, figure I'd list them in one place to connect all the individual ads for anyone looking to combine shipping. All prices are OBO and do not include shipping unless noted. PM or post any questions.
1)
2) OEM standard black lock pins and Chrome door pulls: http://forums.vwvortex.com/showthre...-Pulls-and-Lock-Pins-and-Pair-of-Chrome-Black
3) New in box chrome/stainless hood pin set. $20 shipped. (Sold)
4) 288mm / 11.3" 1.8T Front Brake Carriers: http://forums.vwvortex.com/showthread.php?4874937-FS-288mm-11.3-1.8T-Front-Brake-Carriers-(LI-NJ)
6)
7) Set of 4 OEM 1.8T AWP 317cc Fuel Injectors: http://forums.vwvortex.com/showthre...of-4-OEM-1.8T-AWP-317cc-Fuel-Injectors-(LI-NJ)
8) OEM front rebar. $20 picked up.
9)
10) Battery Box Parts from my 2002 GTI 1.8T: http://forums.vwvortex.com/showthread.php?4874921-FS-Battery-Box-Parts-from-my-2002-GTI-1.8T-(LI-NJ)
11) OEM sunroof motor from my 2002 GTI. SOLD
12) Rear brake rotors. 9.1" solid rears from my GTI. Only about 10k miles on them, are geomet coated. Also have ceramic pads to go with them. $45 shipped.
13)
14) Aftermarket Ball and Cone Seat Wheel Lug Bolts: http://forums.vwvortex.com/showthre...ket-Ball-and-Cone-Seat-Wheel-Lug-Bolts-(LI-NJ)
15) Hawk HPS Brake Pads Front and Rear, ECS Wear Sensor Bypass: http://forums.vwvortex.com/showthre...and-Rear-ECS-Wear-Sensor-Bypass-Rotors-(LI-NJ)
16)
17) Custom Wireless Dual Stage Manual Boost Controller MBC Setup: http://forums.vwvortex.com/showthre...tage-Manual-Boost-Controller-MBC-Setup-(LI-NJ)
18) Stock 1.8T Throttle Body Hose and AWP turbo inlet hose/pipe: http://forums.vwvortex.com/showthre...Body-Hose-and-Pancake-Pipe-Boost-Hoses-(LI-NJ)
19) VR6 and 1.8T Intake Airboxes Air Boxes: http://forums.vwvortex.com/showthread.php?4873569-FS-VR6-and-1.8T-Intake-Airboxes-Air-Boxes-(LI-NJ)
20) OEM exhaust manifold. Off my 2002 GTI 1.8T, 115k miles on the turbo and mani. $30 shipped for the manifold.
21)
22) Pair of black cloth rear floor mats out of my 2002 GTI. Saw very little use and time in the car, great condition. $20.
23) 2 x Passenger side and 1 x driver side door seal for a 2-door GTI. Black rubber with gray cloth. Also have 1 hatch seal. $35 shipped each.
24) pair of black seat belts from the rear of my GTI. Also have the three seat belt receptors from the rear. $20 per belt. $20 for all three receptors. $50 shipped for everything.
25)
27) Ingall's lower control arm extenders. Allows you to dial in more negative camber on your MK4. $105 shipped.
28)
29) VF Engineering front sway bar replacement end links. $100 shipped. (Sold)
30) Stock front sway bar end links with well worn poly bushings $18 shipped
31) Pair of 1.8T stock spindles with hubs, wheel bearings, speed sensors and ball joints. $100 shipped. (Driver side sold)
32)
$FREE Stuff:
1)
FEELERS:
1) Some air conditioning, secondary air injection (SAI), and EVAP systems. $MakeOffer
2)
3)
SOLD LIST:
-OEM chrome GTI 1.8T letters. 1.8T is broken between the 1 and 8. $8 shipped SOLD
-OEM Audi TT short shifter for pre-2002 (AWD, AWW) cars with ball and socket-style shift cable end links. Discontinued part # 8n0 711 051. $45 shipped SOLD
-OEM push-down coil packs, 4 total. $10 shipped each, all 4 for $35 shipped. SOLD
-OEM 02J Shift Tower, $45 shipped. SOLD
-ECS wheel hanger tool, $12 shipped. SOLD
-ECS clutch alignment tool, $15 shipped to Canada. SOLD
-Pre-Cat O2 sensor, $20 picked up. SOLD
-TSW Hockenheim R wheels. $450 picked up. SOLD
-OEM OBD2 Window Solar Panel Trickle Charger. $20 picked up. SOLD
-OEM black dummy dash switches SOLD
-OEM brushed door pulls SOLD
-Cone seat lug bolts SOLD
-OEM Shift Cable Ends SOLD
-OEM 1.8T 'pancake" pipe
-OEM 20th/337 Edition GTI door sill covers. $25 shipped SOLD
-Redline MT-90 2 x 1L bottles, magnetic drain plug. $25 shipped SOLD
-BBS RC 18" wheels. SOLD
-R-line hood bra SOLD
-20th AE Recaro seats SOLD
-Recaro Speed seat and Schroth harness SOLD
-Auxiliary Input box SOLD
-OEM Clear Turn Signal Fender Repeaters SOLD
-OEM black GTI/Golf rear cargo cover/shelf SOLD
-OEM stock 1.8T early intercooler. Bigger version from my 2002 GTI. Comes with the rubber IC duct. Some bent fins on the front surface, and the 2 screw heads for the MAP sensor broke off so you'll have to extract those. SOLD
-Complete TDI 5th gear 0.756 conversion kit SOLD
-Pair of Continental ContiSportContact tires GONE
-12.3" (312mm) brake upgrade kit. Includes rotors with 5k miles, choice of pads with 10k miles, and brand new carriers. SOLD
-OEM Monsoon radio, amp, and 2 speakers SOLD
-1.8T MAF sensor and housing SOLD
-SPC Rear Toe Adjustment Shims SOLD
-Heated Seat Harness and Switches. SOLD
-OEM car cover SOLD
-Monsoon speakers and tweeters SOLD
-OEM 710P DV SOLD
-AWP ECU SOLD
-Votex mud flaps SOLD
-R-line carpet mats SOLD
-Free locking lug bolts SOLD
-Autometer Boost Gauge SOLD
-SAI hoses SOLD
-eBay SMIC SOLD
-Brushed aluminum lock pins SOLD
-k03s SOLD
-LeBra car cover SOLD
-Used Bildon / VW Racing stud conversion kit
-Venair TIH
- GIAC ECU
- Siemens 630cc high impedance injectors
-HRE 449R wheels
-hood latch
-GTI hood
-AC compressor
-shift knob
-driver and passenger axles
-ECS stage 1 clutch kit
Discussion Starter #5
Re: (sc_GTI)
Quote, originally posted by sc_GTI »
the TT short shifter is 50 brand new from ecs, if you decide to drop the price of it to 25-30 pm me
The short shifter that ECS has for $57.41 is not the same part number as the TT short shifter that I am selling. The one I have is no longer available, and uses the early style "ball and socket" end links, while the ECS one utilizes later style "pin and clip" end links. I'll sell mine for $40 shipped, which saves you from having to buy the updated endlink and clip for an additional $24.
Re: (4ceFed4)
good price on the shift tower, just had to buy one for 170 from the dealership http://****************.com/smile/emthdown.gif
i need passengers side view mirror and would prolly take front bumper if it is in good shape, i live in queens i can come pick it all up
1 - 20 of 144 Posts
