1 - 20 of 242 Posts
Banned
I'll start this off. Pleese add your own, lets make this BIG!!
1. 944? heater control sliders fit a2's
2. Some models of Jaguars have straight threw resonators that could be used in a home made performance exhaust
3. 4 lug wheels off any non-quattro audi will bolt up to our cars (Ronal R8!!)
4. hydro brackets are $8 at a junker vs. $40 from TT!!
http://picknpull.com/ <pick n pull>
http://car-part.com/ <used part search engine>
http://www.pickapart.com/ <pick a part>
http://www.junkyarddog.com/ <find a yard / recycler in your area>
Modified by H2o at 4:42 AM 1-1-2004
Re: ::: Guide to JunkYard Tuning ::: (H2o)
Quote, originally posted by H2o »
audi 5000 4 lug is 4X108 IIRC, but 4000 (non quattro) 4 lug is 4X100
I have a ton.. but ill give you a few that prolly won't be mentioned..
1. later Hyundai's w/ the bosch fuel injection, and either the 12V or 16V engine have Bosch idle stabilizers and they are the same exact ISV's as
CIS-E engines (16v's and 8v's) and normally these hyundais have low miles and is a cheap option to buying a new one from the VW dealership.
2. Early Audi's (4000's, and Coupe/Coupe Quattros) normally around the 85/84 and earlier years steering wheels as small splined MK1's and Mk2's..
3. same as above w/ earlier porsches.. but really you will only find 924's (looks like early mk1 rocco and mk1 gti steering wheels) or maybe a 944 if you're lucky.
4. audi 5000 turbo's have the dual piston calipers that are compatible to rado, and possibly 10.1 brakes.. to add some added braking power..
5. e30 3 series have trunk mounted batteries stock, good if you wanna spend a little time pulling it..
im sure there is more.. just a couple neat ones off of the top of my head...
cheers
Matt
Re: ::: Guide to JunkYard Tuning ::: (VWUberAlles)
Below, you can find all the vehicles with the Bolt Pattern 4x100 in North America that will fit our VWs. Only 57.1 center bore or bigger will fit, so that is all that I've included.
H = High Positive Offset - FWD ( Front Wheel Drive ) Typically +45, 40, 35 offset
M = Medium Offset - RWD ( Rear Wheel Drive) Typically +20 offset
L = Low Offset - RWD ( Rear Wheel Drive ) Typically 0 offset
MAKE............MODEL...................YEAR.....OE SIZE.....LUG NUT..........CB........ET
VW...............CABRIO.................97-on.....14 X 6........12mmX1.5b.....57.1......H
VW...............CORRADO..............89-92.....15 X 6........12mmX1.5b.....57.1......H
VW...............GOLF......................85-98.....14 X 6........12mmX1.5b.....57.1......H
VW...............JETTA.....................81-98.....14 X 6........12mmX1.5b.....57.1......H
VW...............PASSAT..................90-97.....14 X 6........12mmX1.5b.....57.1......H
VW...............QUANTUM...............82-89.....14 X 6........12mmX1.5b.....57.1......H
VW...............SCIROCCO 16v.......81-88.....14 X 6........12mmX1.5b....57.1......H
SATURN........S SERIES.................91-on.....14 X 6........12mmX1.5......57.1......H
PONTIAC......LE MANS...................88-93.....13 X 5.5.....12mmX1.5......57.1......H
PLYMOUTH....HORIZON,OMNI.........79-90.....13 X 5........12mmX1.5......57.1......H
PLYMOUTH....RELIANT...................81-85.....13 X 5........12mmX1.5......57.1......H
PLYMOUTH....VOYAGER.................81-85.....13 X 5.5.....12mmX1.5......57.1......H
NISSAN........NX 2000...................91-93.....14 X 6........12mmX1.25....59.1......H
NISSAN........PULSAR SE...............87-90.....14 X 6........12mmX1.25....59.1......H
NISSAN........PULSAR XE...............87-90.....13 X 5.5.....12mmX1.25....59.1......H
NISSAN........SENTRA....................87-on.....14 X 6.......12mmX1.25....59.1......H
NISSAN........200SX......................95-97.....13X5,14x5.5.12mmX1.25..59.1......H
NISSAN........200SX SE-R..............95-97.....15 X 5.5.....12mmX1.25....59.1......H
ISUZU.........I-MARK TURBO..........87-89.....14 X 6........12mmX1.5......60.1......H
ISUZU.........IMPULSE...................83-92.....14 X 6........12mmX1.5......60.1......H
ISUZU.........STYLUS.....................91-on.....14 X 6........12mmX1.5......60.1......H
DODGE........CARAVAN.................84-85.....14 X 6........12mmX1.5......57.1......H
DODGE........RAMPAGE.................78-85.....14 X 6.........12mmX1.5......----......H
DODGE........ARIES......................81-86.....13 X 5.5......12mmX1.5......57.1......H
DODGE........CHARGER 2.2...........82-86.....13 X 5.5......12mmX1.5......57.1......H
DODGE........COLT.......................93-94.....13 X 4.5......12mmX1.5......57.1......H
DODGE........DAYTONA.................82-84.....14 X 6........12mmX1.5......57.1......H
DODGE........NEON.......................94-96.....14 X 5.5.....12mmX1.5......57.1......H
CHEVROLET.CHEVETTE................75-86.....13 X 5........12mmX1.5......57.1......H
BMW...........318,325....................84-91.....14 X 6........12mmX1.5b....57.1......M
BMW...........320,323....................79-83.....13 X 5.5.....12mmX1.5b....72.56.....M
AUDI..........4000.........................79-84.....14 X 6........12mmX1.5b....57.1......H
AUDI..........4000S.......................76-84.....13 X 5.5.....12mmX1.5b....57.1......H
AUDI..........COUPE......................79-84.....14 X 6........12mmX1.5b....57.1......H
AUDI..........FOX..........................76-84.....13 X 5.5.....12mmX1.5b....57.1......H
AUDI..........80,90 QUATTRO.........To '87.....13 X 5.5.....12mmX1.5b....57.1......H
Re: ::: Guide to JunkYard Tuning ::: (Estonian)
my rabbit had some chrysler rims on it when i got it, and the centre bore was too small and the wheels wouldn't bolt on straight, they wobbled when you drove it
this is kinda what i looked like driving it home ->
Banned
Discussion Starter · #14 ·
Audi 5000's have a CAI type of tube hooked up to there airbox
which can be used in a DIY CAI
M1 (posibly M2) Miatas also have a trunk mount battery, the battery it self is a small gel-cell.. I'm not sure if it could crank over an mkII or not
Very well might. I don't think the Miata has that much smaller of an engine. Just use really heavy cables to get max juice up front.
Re: ::: Guide to JunkYard Tuning ::: (vwgti1986)
I am using Dodge wheels on my rally car and the center boar was .5mm to small but less than 30 seconds with a die grinder fixed that. They are 15" wheels and strong as all get out. Off a Dodge Charger Turbo.
Banned
Discussion Starter · #19 ·
Junkyard Turbo List
http://www.gamesbbs.com/~turbo....html
Last updated: 09/06/2002
AUDI-Europe 200 88 2.2L KKK K26
AUDI-Europe 200 88-91 2.2L KKK K24
AUDI-Europe 200 Quattro 91 2.2L KKK K24
AUDI-Europe 5000 80-88 2.2L KKK K26
AUDI-Europe 5000 Diesel 2.0L 88 KKK K24
AUDI-Europe 5000 Quattro 82-88 2.2L KKK K26
AUDI-Europe S4 Quattro 92-94 2.2L KKK K24
AUDI-Europe S4 Biturbo/tt-180 99 2.7L/1.8L KKK K03
AUDI-Europe TT-225hp 99 1.8L KKK K04
AUDI A3, A4, A6, Cabriolet 1.8L,/1.9L diesel GAR GT-15
BMW 324TD/524TD 83-86 GAR TB0324
BMW 745I 84-86 KKK K27
BUICK GNX 87 3.8L GAR TB0348
BUICK Monte Carlo/Regal 78-83 3.8L carbed GAR TB0348
BUICK Riviera 80-85 3.8L GAR TB0308
BUICK Grand National/T-Type 86-87 3.8L (Intercooled) GAR TB0348 (TA48)
BUICK Trans Am 89 3.8L GAR TB0348 (water)
BUICK Century 78 3.8L GAR TB0301
BUICK Century 79 3.8L GAR TB0304
BUICK Century 80 3.8L GAR TB0308
CHEVY Sprint 1.0L IHI RHB31
CHEVY Spectrum 85-90 1.5L IHI RHB521
CHRYSLER Conquest, Intercooled 87 2.6L MHI TD05
CHRYSLER Laser (Auto) 90-94 2.2L MHI TD04
CHRYSLER Laser (Manual) 90-94 2.2L MHI TD05H
CHRYSLER LeBaron 89-92 2.5L MHI TE04H
CHRYSLER LeBaron 88 2.5L MHI TE04H
CHRYSLER New Yorker 88 2.5L MHI TE04H
CHRYSLER New Yorker 84-87 2.2L GAR TB0335
CHRYSLER Town & Country 88 2.2L MHI TE04H
CHRYSLER Town & Country 84-87 2.2L GAR TB0335
CHRYSLER Charger/Shelby 87-90 2.2L GAR TB03 (water)
CHRYSLER Shelby CSX-Daytona/Baron GTC/Shadow ES 89-90 2.2L GAR TB03 VNT (variable nozzle)
DODGE 600 88 2.5L MHI TE04H
DODGE 600 85-87 2.2L GAR TB0335
DODGE Aries 88 2.2L MHI TE04H
DODGE Caravan 89-90 2.5L MHI TE04H
DODGE Conquest (Intercooled) 87 2.6L MHI TD05
DODGE Daytona 89-92 2.5L MHI TE04H
DODGE Daytona Shelby 88 2.2L MHI TE04H
DODGE Daytona Shelby 84-87 2.2L GAR TB0335
DODGE Lancer 89 2.5L MHI TE04H
DODGE Lancer 88 2.5L MHI TE04H
DODGE Lancer 85-87 2.2L GAR TB0335
DODGE Omni 85-87 2.2L GAR TB0335
DODGE Shadow 89-92 2.5L MHI TE04H
DODGE Shadow 88 2.5L MHI TE04H
DODGE Shadow 87 2.2L GAR TB0335
DODGE Spirit 89-92 2.5L MHI TE04H
EAGLE Talon (Manual) 90-94 2.0L MHI TD05H (45 trim)
EAGLE Talon (Auto) 90-95 2.0L MHI TD04
EAGLE Talon (Manual) 95-98 2.0L MHI T25 (45 trim)
FORD Mustang GT 85-86 2.3L GAR TB0344
FORD Mustang GT/T-bird 83-84 GAR (AiR) TB0344
FORD Probe GT 88-92 2.2L IHI RHB52W
FORD T-Bird 85-86 2.3L (auto) GAR (AiR) TB0344 (45 trim oil only)
FORD T-Bird 85-86 2.3L (Manual) GAR (AiR) TB03 60 trim (watercooled)
FORD T-Bird 87-88 (water) IHI RHB52
FORD Fiesta 90+ 1.6L GAR T2
FORD Escort 84-86 IHI RHB5
ISUZU MPR Truck 88-92 IHI RHB6-A
MAZDA 626, MX6 88-92 2.2L IHI RHB52W
MAZDA 323 GTX turbo 88-89 1.6L IHI RHB52W (water)
MERCEDES 300D, SDT, TD 78-84 3.0L GAR TA0301
MERCEDES 300SDL 78-83 3.0L GAR TA0301
MERCEDES 300SDL (Calif.) 86-87 3.0L GAR TB0359
MERCURY Capri 85-86 2.3L GAR TB0344
MERCURY Cougar 85-86 2.3L GAR TB0344
MERKUR XR4Ti 85-88 2.3L GAR TB0344
MITSUBISHI Eclipse (Auto) 90-94 2.2L MHI TD04
MITSUBISHI Eclipse (Manual) 90-94 2.2L MHI TD05H
MITSUBISHI Eclipse (Manual) 95-98 2.0L MHI T25 (45 trim)
MITSUBISHI Galant (Auto) 88-94 2.2L MHI TD04
MITSUBISHI Galant (Manual) 88-94 2.2L MHI TD05H
MITSUBISHI Starion (Intercooled) 85-87 2.6L MHI TD05
MITSUBISHI 3000GT VR4 - 2x MHI TD04H
PLYMOUTH Acclaim 89-92 2.5L MHI TE04H
PLYMOUTH Caravelle 88 2.5L MHI TE04H
PLYMOUTH Caravelle 85-87 2.2L GAR TB0335
PLYMOUTH Conquest, Intercooled 85-89 2.6L MHI TD05
PLYMOUTH Laser (Auto) 89-94 2.0L MHI TD04
PLYMOUTH Laser (Manual) 89-94 2.0L MHI TD05H
PLYMOUTH Sundance 89-92 2.5L MHI TE04H
PLYMOUTH Sundance 88 2.5L MHI TE04H
PLYMOUTH Sundance 87 2.2L GAR TB0335
PLYMOUTH Voyager 89-90 2.5L MHI TE04H
PONTIAC Sunbird GT 88-90 2.0L GAR T2
PONTIAC Sunbird GT 84-86 1.8L GAR T2
PONTIAC Grand Prix 89-90 3.1L GAR T25 (water)
SAAB 9000 (16V Intercooled) 87-88 2.0L GAR TB0356
SAAB 900 (16V Intercooled) 87 2.0L GAR TB0339 (Oilcld)
SAAB 900 (16V Intercooled) 84-86 2.0L GAR TB0339 (Oilcld)
SAAB 9000 (16V Intercooled) 85-86 2.0L GAR TB0343
SAAB 900 (8V, APC) 82-84 2.0L GAR TB0321
VOLVO 200 82-84 2.3L GAR TB0313
VOLVO 740 89-93 2.3L MIT TD04H
VOLVO 740 87-89 2.3L MIT TD05
VOLVO 760 89-93 2.3L MIT TD04H
VOLVO 760 87-89 2.3L MIT TD05
VOLVO 780 85-87 2.3L GAR TB0363
VOLVO 780 90 2.3L MIT TD04H
VOLVO 780 87-89 2.3L MIT TD05
VOLVO 940 91-93 2.3L MIT TD04H
VOLVO 200 Watercooled Upgrade 82-84 2.3L GAR TB0368
VOLVO 740 (Oil Cooled) 83-85 2.3L GAR TB0326
VOLVO 740 (Watercooled) 85-87 2.3L GAR TB0363
VOLVO 760 (Oil Cooled) 83-86 2.3L GAR TB0326
VOLVO 760 (Watercooled) 85-87 2.3L GAR TB0363
VW Passat, 97+ (oil) 1.8L GAR GT15
GAR=Garrett=AiResearch, MHI=Mitsubishi Heavy industries, MIT=Mitsubishi
Compiled by Randy Gazdecki.
While I have attempted to keep this list as accurate as possible, I cannot guarantee the accuracy or completeness of this list. Use as a reference only.
1 - 20 of 242 Posts
