Status
Not open for further replies.
1 - 7 of 7 Posts
Looking for that perfect handling with reduced body roll and an all around more aggressive feel? - Than HS Tuning has you covered! We have just added the full line of H&R Audi front and rear sway bars to out site and have priced them competitively. Your H&R Sway bar will come with the shims and hardware required for a proper install. Installation time varies on model. General estimate around 45 Minutes to an hour.
H&R Sway Bars are truly something special in the world of automotive suspension components. Using specialized machines designed by H&R, H&R Sway Bars are formed perfectly for each and every application, ultimately providing an unmatched level of precision fitment and performance.
H&R Sway Bars are crafted from a special 50CrV4 steel alloy –– the highest tensile strength available and the industry’s strongest and most durable. The true consistency of this special alloy guarantees smooth transitions in sway bar function.
A unique feature of H&R sway bars are the machined-like forged ends that are adjustable for fine-tuning. H&R sway bars come equipped with exclusive Urethane/Teflon composite bushings featuring a molded-in fabric-like material that requires no maintenance or lubrication, and eliminates squeaking.
H&R Sway Bars are the perfect compliment to H&R Springs, Coil Overs and Cup Kits. H&R Sway Bars are crafted from a special spring steel that is both stronger and more resilient than competitors sway bars. All H&R Sway Bars are built on specialized machines designed by H&R — the only way to ensure an exact fit and incomparable performance in every application. Each bar is heat-treated and shot-peened — an H&R exclusive process — for increased surface hardness and life. Finally, all H&R Sway Bars are powder coated for long lasting performance, quality and beauty.
Like all H&R components, H&R Sway Bars are 100% Made in Germany to exacting ISO 9001 and TÜV Certification standards, guaranteeing the highest quality and best performance.
Whatever Audi model you have, we can help!
H&R A3 Sway Bars - BUY HERE!
H&R S3 Sway Bars - BUY HERE!
H&R A4 Sway Bars - BUY HERE!
H&R S4 Sway Bars - BUY HERE!
H&R RS4 Sway Bars - BUY HERE!
H&R A5 Sway Bars - BUY HERE!
H&R S5 Sway Bars - BUY HERE!
H&R RS5 Sway Bars - BUY HERE!
H&R A6 Sway Bars - BUY HERE!
H&R TT Sway Bars - BUY HERE!
H&R TTRS Sway Bars - BUY HERE!
Sway Bar in blue - Used on some S and RS models:
This color is anything but dull - The paint has a has a metallic shine to it which will take this bar stand out!
If you have any questions, Please contact us through the PM here, or at [email protected]
I'm in Avon. Can I pick up to avoid shipping charges? edit - I just saw that I can select pick up at no charge.
I'm looking for a firm H&R Sway bar kit on my 2013 Audi TTS with magnetic suspension. I see there are a lot of options and different part numbers. Which are the ones that fill fit my car front and rear? Can you please PM me the best price you can do?
Thanks.
When will the sale end?
1 - 7 of 7 Posts
Status
