Re: Had my transmission fluid replaced w/ Redline. (ksanchez)
quote:[HR][/HR]Is this something you can do yourself? I'm interested in doing it if it doesn't require a lot of tools, etc... I've never even done my own oil changes, though I'm interested in learning.
-ks[HR][/HR]
This is a bit trickier than changing your oil, not much though...
17mm hex nut and a fluid pump of some sort are all you need....
jack the car out, remove 17mm plug on bottom of tranny, drain oil, replace plug, remove 17mm plug on FRONT of tranny then use the fluid pump to put the 2 quarts in until it overflows..... not too hard.
quote:[HR][/HR]not bad for $30[HR][/HR]
http://****************.com/smile/emthup.gif tru dat
