1 - 4 of 4 Posts
I changing the shot auto tranny in my '85 Jetta GL. I got another tranny for it and just noticed a problem. The "axle cups" are smaller on the new tranny. The old shafts won't bolt up (to big). Can I just get the smaller axles and be done with it? If so, what size do I need? I'm still removing the old tranny. So far I noticed the torque converter bolts are broke off of the flywheel and it seem to be weged together.
Need replys ASAP.
Discussion Starter · #2 ·
Re: Haft shaft q's, help ASAP (BlownGinster)
Also, will the larger shafts fit my '92 gti 8v? I'd hate to waste 2 good axles.
Thanx
Prob need to swap 90mm inner joints onto your axles, or if the shafts will clear the casing, just swap the 100mm flanges from the other transmission?
Discussion Starter · #4 ·
Thanx. Is there any reason the 90mm shaft wouldn't fit? The joints are the same price as the whole axle!!
1 - 4 of 4 Posts
