That cool [emoji41]. Not sure how mine will play as I also have the LSD installed up front... [emoji4]I did my first donuts last week. I'm pretty bad at them, and not a lot of places to practice here. I can get the tail to move somewhat consistently on the back roads in this area which maybe is more fun anyway.
HNNNNNNNNNNNNNNNNNNNGHHHHHHH. Awww yeaaa thats the stuff... right into my veins!Front and rear Wavetrac on a TTRS 8S...
Traction pack
[video]https://www.facebook.com/onelapttrs/videos/579407222686896/[/video]
Traction pack
What a tease! Any chance at a video clip?Ok Guys.
My rear diff is in place and I have done one test drive.
The condition was wet and I still run on winter tires!
When at exit on sharp bends. I am now able to get the back end very easily if wanted! The car is "dancing" with the tail now! [emoji4] This is even with the front LSD install [emoji41]
Need more testing to report back with.
But at this point it feels very good [emoji851]
Sent fra min SM-N975F via Tapatalk
Haha [emoji23]. I am not trying to tease. Will see what I can make. But in these times it's not easy to any meetings with friends... [emoji4]What a tease! Any chance at a video clip?
Congratulations! You must be 7 heaven high.Ok Guys.
Did you run into any traction control issues when doing so? I have a 2018 6MT with just the rear lsd and I find that even with the traction control "off" (hold button down) it will still cut in if the car flips around too quickly. A few months ago I was working through this issue with ICETER but lately I haven't had the time to try some VCDS options out but I can get the donuts to work if I pull the ABS fuse. Are you running any suspension mods or different tires also?I did my first donuts last week. I'm pretty bad at them, and not a lot of places to practice here. I can get the tail to move somewhat consistently on the back roads in this area which maybe is more fun anyway.
Have you turned XDS off? Even with traction control off, this will still intervene. If it’s not turned off with VCDS or OBD11, it will fight you with the LSD.Did you run into any traction control issues when doing so? I have a 2018 6MT with just the rear lsd and I find that even with the traction control "off" (hold button down) it will still cut in if the car flips around too quickly. A few months ago I was working through this issue with ICETER but lately I haven't had the time to try some VCDS options out but I can get the donuts to work if I pull the ABS fuse. Are you running any suspension mods or different tires also?
Ascho said:Did you run into any traction control issues when doing so? I have a 2018 6MT with just the rear lsd and I find that even with the traction control "off" (hold button down) it will still cut in if the car flips around too quickly. A few months ago I was working through this issue with ICETER but lately I haven't had the time to try some VCDS options out but I can get the donuts to work if I pull the ABS fuse. Are you running any suspension mods or different tires also?
This and you will most likely damage something in the process if you keep XDS on at all, it needs to be fully off. And just as a double check, when you hold the ESC button, your MFD displays "ESC OFF" and not "ASC OFF" right?Have you turned XDS off? Even with traction control off, this will still intervene. If it’s not turned off with VCDS or OBD11, it will fight you with the LSD.
I missed out on the season first Trac event. So can't say how it will work with the front end rear LSD combo... [emoji4]Congratulations! You must be 7 heaven high.
I would be extra careful because the front LSD will put the front wheels to do more "work" and may turn the tide and make it feel again like a fwd.
Yes, I deactivated my XDS within the first month of getting the car, looooonng before I even got the rear LSD. And when I did have it installed I double-checked and made sure it was still off, so that's not the problem.
Yes. I have finally tested the car on track with front and rear Wavetrac LSD [emoji16] [emoji106]Any update on review the rear LSD? And how it works with the front LSD?
Stop this nonsense! They have been talking about this for years. I don't believe it a bit!Wavetrac is working on a rear diff which would be cheaper than this since it will droop into the casing without the need to modify anything. They are currently in the process of getting it to market soon. How soon is soon, is another question.
