1 - 20 of 507 Posts
09 CC 3.6 4mo, 98 DE Leftover car, 90 Corrado, 78 Triumph Spitfire
passat rear pan?
You can drop off that parts collection to colorado :p :sly:
Rallye golf rear section.
Sure what's the address?:D
Much cleaner and made of unobtainium!!!!!!!. Care to make a CAD design of that rear crossmember? :D
I`m in the same boat , I got the rally golf pan but all the other parts are NLA . Looks like somebody will be doing some custom work for the rest of it . On another note , how much difference is there between the rally golf fuel tank and the passat syncro tank . Since there will be fab work in my future , the passat tank is a little easier to find here in the US .
well...since I already have the passat rear crossmember, can you hook this guy up with some leads on a passat tank? :D
So what parts are needed for the haldex conversion? like what car are the gearbox and rear differential from? also, I remember seeing that the golf rallye rear panel was sold seperately, from VW , what was the part nr? are you still going to use the 12V VR6?
why is haldex better over syncro, I wanna learn as much as possible about that swap.
thanks.
thanks.
then you should start in the synchro forum. :rolleyes:
rallye golf rear pan in unobtanium... Kevin bought the last one a few years ago.
1 - 20 of 507 Posts
