1 - 9 of 9 Posts
FV-QR
so you'd be using the torsen as the center diff ? Without a center diff there will be all sorts of problems.
Or would you be doing this to replace the clutch packs?
You realize how the Torsen works?
You have no way to send the torque back to the front axle.
The transfer case is full time off the transmission.
I.E it will not work.
Hello, sorry to bring back and old post, but I'm on and early design project to solve this and make it work... is based on the idea of bypass the haldex after install a torsen t3 twin type of front/center differential, in the original front diferential case. I'll be updating if I sucess in it.
Hey, not trying to revive an old thread but was wondering if you found a way to make this work? I’m doing a Haldex swap on my Mk4 GTI, but I’ve found the Haldex lacks. I want all time AWD. It’s my track build, so I don’t care about how long or how much it will take. I was planning on using the rear diff from a A4
1 - 9 of 9 Posts
